SNMP is polled every 5 minutes to populate the graphs here:
https://monitoring.hamwan.net/cacti/graph_view.php?action=tree&tree_id=1
Sectors are polled hourly to search for new wireless connections. Based on the code I linked, you can see that it only does a single SNMP poll of new devices (it never updates their data, only inserts).
Tom
On Fri, Jun 2, 2017 at 12:34 PM, Daniel Luechtefeld <daniel.luechtefeld@gmail.com> wrote:
How often are the SNMP agents polled?
73, Daniel K7DGL
On Fri, Jun 2, 2017 at 12:17 PM, Tom Hayward <tom@tomh.us> wrote:
Hi Dave,
I've been super busy with work lately and haven't had much time to work on HamWAN software. If you (or anyone else on this list) wants to add support for changing locations, the code is here:
Submit a pull request and I'll review and deploy it.
For multiple addresses, we'd rather set up a routed subnet for you than assign multiple with DHCP. Those types of requests should be directed at netops@hamwan.org. We'll need to assign a subnet, then configure it on both the sector and your modem. Then you would run a DHCP server on the modem to assign the new addresses to devices on your LAN.
Before we set up your new subnet on the sector, you might want to try connecting to a closer sector. Notice how you're connected to Capitol Peak. ETiger should work really well from Federal Way. Did you try pointing the antenna that direction? Gold and Baldi should also work nicely.
Tom
On Fri, Jun 2, 2017 at 12:03 PM, David Swartz <david@swartzfamily.org> wrote:
Dear Hamwan team,
I forwarded the notice about the wrong location to Craig Baker the FWARC digital communications chair yesterday.  I talked to him and he tells me that he initially entered the wrong coordinates.  He the same day we went online and notice the wrong location plotted he changed the coordinates to the correct location.  Apparently the hamwan system didn't pickup that change.  He doesn't know how to have the hamwan system propagate this change to update the plotted location to the correct one.
Please help us make this right.
We are also having trouble with the setup of the radio.  If there is anyone within the hamwan organization that could mentor and assist us in getting this operational that would be great.  We would like the radio to connect to ham wan and pull down from dhcp at least three distinct IP addresses.  This is to support the three different repeaters that are at the site.
Best wishes,
Dave Swartz
FWARC Repeater Operations
On June 2, 2017 at 12:56 AM KL7WM via PSDR <psdr@hamwan.org> wrote:
No, the Vashon Island address is wrong.  I probably came from a Packet Node error
The address is 30926 8th Ave S, Federal Way, Latitude  47.3246 N, Longitude -122.3259 W.   MSL 526 and tower height 120
Thank you
Daniel Stevens KL7WM
In a message dated 6/1/2017 5:06:58 P.M. Pacific Daylight Time, daniel.luechtefeld@gmail.com writes:
The node map on the hamwan.org website shows WA7FW as being on Vashon Island. Is this correct?
73, Daniel K7DGL
"Mission is a profound sense of purpose; an anchor in a truth outside oneself which gives substance to the resolve not to quit."  --- Viktor Frankl
