_______________________________________________Let’s keep in mind that “encryption” means purposefully hiding/obfuscating/coding information with intent of unauthorized users to discover/decode the information. To accomplish encryption, both a cipher and a key are needed; the cipher is an algorithm-driven means to hiding the information and the key is used to perform the encryption and decryption. Symmetric encryption uses a single key shared between authorized users, whereas asymmetric encryption typically uses mathematically related key pairs…it is the latter that is done with TLS/SSL via the Public Key Infrastructure. Regardless of how it is done, encryption by definition is used to keep information private to those who do not know the cipher or have the correct key, which is not legal in Part 97 for any purpose as I read it, whether for authentication, integrity, or confidentiality of communications.
As we hams know, there are methods of “coding” information that may seem like purposeful encryption, but are not because the ciphers and keys are publicly, even widely, available to anyone. Examples include Morse Code, CRC checksums (for integrity), IPA, digital communications protocols OTA, etc. These are not encryption (contrary to how some old hams argue who do not understand PSK31 or other “new” digital protocols for example). So the question pertaining to what we’re discussing is: is the intent to purposely make the data private for some by a few or even a group of only those people (or machines/programs) who know the cipher used and have the key to decode? Apparently the connection from default installation of Winlink Express for Windows to CMS does intend to keep that traffic private using a method very difficult to break encryption for most public observers (at least when local RMS is performed during the install).
From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Aaron Taggert
Sent: Tuesday, March 16, 2021 8:27 AM
On the authentication/integrity side... FCC says no encryption so we can all hear what you're on about. Ham would not be much fun if all you heard was encrypted pseudo noise. SSL/TLS authentication is a bit like me sending you a list of 100 words and asking you to tell me word 45. Everything is in the clear, but I can authenticate that whomever is at the other end at least has the right list. Another SSL/TLS feature is integrity, meaning the whole message is received. They would be like saying I sent 3421 characters CW 786 of them were vowels. Again everybody can hear what we're saying but it would be difficult to impersonate the sender (or receiver) or change the message.
On Tue, Mar 16, 2021, 6:32 AM Steve - WA7PTM <psdr-list@aberle.net> wrote:
telnet mode?
> -Scott
>> Scott, thanks for that update, interesting. “Telnet” is a misnomer in
>> (whereas SSH is encrypted). It looks like the email client is connecting
>> internet.
>> --Stephen W9SK
>> Winlink Express Link Test:
>> Successfully connected to a CMS through port 8772 in 253 Milliseconds
>> Successfully connected to a CMS through port 8773 in 311 Milliseconds
>> Successfully performed API service to api.winlink.org through port 443
>> in 756 Milliseconds
>> autoupdate2.winlink.org...
>> Successfully checked autoupdate server through port 443 in 439
>> Milliseconds
>> Successfully connected to www.winlink.org through port 443 in 47
>> Milliseconds
>> Successfully connected to ftp://ftp.swpc.noaa.gov/pub/latest/SGAS.txt
>> -Scott, NS7C
>> hoster & client. Winlink does NOT use encryption, thus is legal, and is
>> the primary application for my ARES team using HamWAN. As Kenny points
>> FWIW, Stephen W9SK
>> Good luck,
>> Kenny, KU7M
>> Hi Phil,
>> dish. As to “just over them”, a microwave shot consists of the direct,
>> cigar shaped “balloon” around the pure line of sight. Items in the Fresnel
>> regular internet and HamWAN for a Winlink node. My suggestion would be to
>> other if the one goes down. You can also acquire routers that include
>> failover capability to automatically make that switch. You can go more
>> Carl, N7KUW
>> PSDR
>> *To:* psdr@hamwan.org
>> and reporting status. I's not linking to anything since the antenna is
>> still on the ground. How much configuration can I do before mounting it on
>> my roof. The only question in my sight path may be some trees but I think
>> I can aim just over them and get a signal. My friend Bruce/WA7BAM will be
>> helping with the antenna installation on Wed afternoon. Making progress...
>> *Phil Cornell *
>> *W7PLC *
>> *SHARES NCS590*
>> *Hybrid Gateway W7PLC*
>> *TCARES VP*
>> PSDR mailing list
>> PSDR@hamwan.org
>> PSDR mailing list
>> PSDR@hamwan.org
>> *-Scott*
>> PSDR mailing list
>> PSDR@hamwan.org
