OK, imported the .p12 certificate into both Firefox and Internet Explorer, and both now show it in the list of personal certificates.  Then, I temporarily disabled routing 44.x.x.x addresses out the MikroTik.  A "traceroute" confirms I'm not going out the MikroTik radio.
I get the same message: "We need to authenticate you, but we can't use encryption over ham radio."  Do I have to reboot Windows?
On 2014-06-08 17:43, Cory (NQ1E) wrote:
Using that specific version of Opera is only if you want to visit the authenticated portal site over the RF network.  It's the only browser that we could get to work with unencrypted SSL mutual certificate authentication.  Nobody else on the internet seems to do that, so there's not a lot of support for it.
If you're using your commercial internet connection instead, you don't have to worry about that and you can use just about any browser if you have your LotW certificate setup in it.
-Cory
NQ1E
On Jun 8, 2014 5:24 PM, "Dean Gibson AE7Q" <hamwan@ae7q.com> wrote:
This requires a specific (and non-current) version of a specific browser (eg, Opera) ?!?!?!?
On 2014-05-15 23:32, Tom Hayward wrote:
On Thu, May 15, 2014 at 9:49 PM, Dean Gibson AE7Q <hamwan@ae7q.com> wrote:
Now, this is not correct.  While I appreciate the PTR record for 44.24.240.173, it needs to point to a hostname record ("A" or CNAME"), not a domainname record.  This is not the fault of the PTR record, but the record that it points to:  The NS record for ae7q.hamwan.net effectively declares ae7q.hamwan.net as a subdomain, with ns1.ae7q.ampr.org as its nameserver.  Now, ns1.ae7q.ampr.org has the IP address of 44.24.240.173, but that doesn't mean that the domain ae7q.hamwan.net is anywhere near 44.24.240.x.
The reason there is an NS record at ae7q.hamwan.net is because I needed to test user NS records while working on the portal UI. On April 10 you talked about running your own DNS server, and complained that ampr.org did not allow NS records. Not wanting HamWAN to be accused of the same thing, I made sure you could create NS records yourself from the portal.
Use your Logbook of the World certificate to log in here: http://portal.hamwan.org/dns/
It will allow you to create, edit, and delete any DNS record within the {LoTW callsign}.hamwan.net domain (e.g., AE7Q.hamwan.net). You can manipulate the records as you see fit.
