Martin,
Since I was just going over the HamWAN spectrum details, here is the page which describes the sector plan.
https://www.hamwan.org/Standards/Radio%20Frequency%20Engineering/Spectrum%20Allocation.html
Because of the limitations of the US sold MikroTik equipment, HamWAN requires purchasing the international versions which have extended coverage into the amateur 5cm allocation.
On Tue, Nov 30, 2021 at 11:49 AM Martin <dcmk1mr2@gmail.com> wrote:
Hello All,
Greetings from SFWEM land.
I have been looking at your documentation and it has improved from the last time I looked. Kudos! I am still finding broken links - is there anyone specific to report these?
 I worked on a OSLR/CDMA Part 15 mesh about a decade ago and am familiar with it's limitations.  While it does have its applications, it's not a great idea for a WAN.
SFWEM has been building nodes for a couple of years but has never done a network level test.  They put up a node, run a speed test and declare success.  I've been encouraging SFWEM to conduct a Simulated Emergency Test.  I would expect a spectacular failure.
I would like to be prepared with alternatives when the AREDN limitations are discovered. I would like to understand your frequency plan.  Your site mentions 5.9 GHz.  Looking at some of the suggested radios (some with broken links) , it looks like the MikroTik coverage ends at 5875 MHz.
It sounds like there is work going on integrating AREDN islands connected to hamWAN.  Any information you can share?
Happy Holidays, Thanks & 73,
Martin Rothfield W6MRR
Berkeley
