On Tue, Jun 2, 2020 at 2:00 PM <psdr-request@hamwan.org> wrote:
Send PSDR mailing list submissions to
        psdr@hamwan.org
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        psdr-owner@hamwan.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of PSDR digest..."
Today's Topics:
   1. Re: VOTE: Baldi LAN expansion and Rattlesnake link (Bart Kus)
   2. Re: VOTE: Baldi LAN expansion and Rattlesnake link (Rob Salsgiver)
   3. Re: VOTE: Baldi LAN expansion and Rattlesnake link (Doug Kingston)
   4. Re: VOTE: Baldi LAN expansion and Rattlesnake link
      (Nigel Vander Houwen)
   5. Re: VOTE: Baldi LAN expansion and Rattlesnake link
      (Dale Skyllingstad)
   6. Re: PSDR Digest, Vol 88, Issue 1 (Colin Stanners)
Message: 1
Date: Mon, 1 Jun 2020 12:01:25 -0700
To: Puget Sound Data Ring <psdr@hamwan.org>, Tom Hayward <tom@tomh.us>
Subject: Re: [HamWAN PSDR] VOTE: Baldi LAN expansion and Rattlesnake
        link
Message-ID: <855d86f1-e969-74ae-77c1-3f43827ce640@bartk.us>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
I'm not sure what there is in there.  Heard vague recollection of a pair
of CAT5s in there, but not with any certainty.  This is why we need to
go survey the place.  I would expect their grounds to be tied given the
power system changes, and the conduit to be bonded. Worst case though we
can omit the shield as CAT5 Ethernet is only magnetically coupled (has
isolation transformers) and uses differential signaling.
I'm kind of hesitant to introduce fiber to HamWAN where it's not
absolutely necessary.  We have enough problems with proper RJ45
terminations, never mind asking people to re-terminate fiber if
something breaks.
Copper Ethernet may be theoretically isolated / only magnetically coupled, but I've seen many cases where ground potential difference of a few volts (e.g. customer PC plugged into an ungrounded outlet) would cause lots of problems over the Ethernet line, sometimes variable and difficult to trace. Same for heavy RF nearby. If cat5 cable is already there it's worth testing, but even if it tests well issues may occur over time, or you may find Ethernet ports fried after a lightning storm.
Also be careful of ground loops when interconnecting buildings - one broadcast tech told me of a big tower NE of Winnipeg where the ground cable between equipment buildings was so hot it would melt snow due to the ground taking a path that it shouldn't have.
The last paragraph is a great point. For setups I often run dual fiber lines and only use one of them, so that there is a spare. If something cuts your conduit and all the fiber lines, you have a bigger problem.
