Thanks, Tom. I'll keep that in mind for the next go-around. Here is the MAC we were using during the test: 4C:5E:0C:31:C4:43It was acting like we were making a connection to the Westin, based on the coordinates that were dialed in. I really wasn't expecting anything from that direction. However, it would be cool to verify if it truly was the Westin that we were passing traffic through. The best RSSI we saw was right around 75.KyleOn Sat, Aug 11, 2018 at 3:11 PM Tom Hayward <tom@tomh.us> wrote:______________________________On Sat, Aug 11, 2018 at 1:27 PM B.J. Guillot <bj.guillot@gmail.com> wrote:
> For grins, he tried the Seattle sectors (~40 km? away), and we got a weak connection. We weren't sure exactly which sector we were hitting (he said there are two it could have been)
It's pretty simple to see which sector you are connected to. Just issue this command:
/interface wireless monitor 0
status: connected-to-ess
channel: 5900/5/an
wireless-protocol: nv2
tx-rate: 16.2Mbps-5MHz/1S
rx-rate: 16.2Mbps-5MHz/1S
bssid: E4:8D:8C:F1:6D:22
radio-name: Gold-S2/K7WAN
signal-strength: -57dBm
signal-strength-ch0: -57dBm
tx-signal-strength: -59dBm
tx-signal-strength-ch0: -59dBm
noise-floor: -120dBm
signal-to-noise: 63dB
tx-ccq: 93%
rx-ccq: 93%
authenticated-clients: 1
current-distance: 10
wds-link: no
bridge: no
routeros-version: 6.41.3
last-ip: 169.48.173.167
current-tx-powers: 6Mbps:31(25/31),9Mbps:31(25/31),12Mbps:31(25/31),18Mbps: 31(25/31),24Mbps:31(25/31), 36Mbps:29(23/29),48Mbps:29(23/ 29),54Mbps:27(21/27),HT20-0: 29(23/29),HT20-1:29(23/29), HT20-2:29(23/29),
HT20-3:29(23/29),HT20-4:29(23/29),HT20-5:27(21/27),HT20-6: 27(21/27),HT20-7:26(20/26)
notify-external-fdb: no
You can see the radio name right there next to the signal strength.
If you can tell me your MAC, I can look you up in the logs to see what sector you connected to.Tom KD7LXL_________________
