Last month I tried to connect from my rooftop and got no signal at all.
Today, I took my setup up to 76th Street, visually aimed it at the tower and connected.
[admin@K7QOG-Paine] > /interface wireless monitor 0
                  status: connected-to-ess
                    band: 5ghz-n-5mhz
               frequency: 5905MHz
       wireless-protocol: nv2
                 tx-rate: 1.5Mbps
                 rx-rate: 1.5Mbps
                   bssid: D4:CA:6D:7A:B8:07
              radio-name: Paine-S2
         signal-strength: -35dBm
     signal-strength-ch0: -35dBm
      tx-signal-strength: -35dBm
  tx-signal-strength-ch0: -35dBm
             noise-floor: -121dBm
         signal-to-noise: 86dB
                  tx-ccq: 10%
                  rx-ccq: 10%
   authenticated-clients: 1
        current-distance: 3
                wds-link: no
                  bridge: no
        routeros-version: 6.7
                 last-ip: 44.24.240.161
So, the next thing I will try is to climb a tree and see if I can get a signal. Wish me luck!
Erik, K7QOG
