I'm not sure what's going wrong, but I can verify that S3.ETiger is running and has 5 clients connected to it.  I suspect you might be aiming at the towers on west tiger (47.508761°, -121.984954°) and (47.504856°, -121.971615°) whereas the HamWAN site is on east tiger (47.488172°, -121.946733°).  From your picture, you should see a 3rd tower or cluster of towers further towards the right, if that is the case.  Google Earth is a good tool to get a sense of the visuals, since it lets you tilt the world.
On 9/11/2021 4:58 PM, Paul Sundquist wrote:
New install on Squak Mountain Issaquah and unable to find any signal on Tiger Mountain. I’m 3.5 miles away west and a little north of the tower on Tiger.
Clear line of sight. Please validate with the tower picture attached.
Installed the following:
MikroTik mANT30 PA parabolic dish antenna 5GHz 30dBi MTAD-5G-30D3-PA
Mikrotik BaseBox 5 RB912UAG-5HPnD-OUT 5GHz Outdoor Wireless AP Gigabit USB OSL4
Questions:
Q1) Is the antenna tower on the right in the picture the right site?
Q3) I was watching the signal strength on the routerboard while running "/interface wireless scan 0”. Nothing showed up on the terminal session and no signal strength LED’s lit up. I moved it left to right and adjusted azimuth each time I stopped.
Q4) How long should you wait to acquire the signal between each time you move it?
Q5) Is there anything like the signal strength tones aiming a DirecTV dish?
Q6) Any other ideas. My exported configuration is below and I’ve successfully completed every step listed here: https://hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configuration.html
Thanks for your help!
-Paul KK7AMW
[admin@KK7AMW-Issaquah] > export
# sep/08/2021 16:57:46 by RouterOS 6.48.4
# software id = H1Z0-P9F3
# model = 912UAG-5HPnD
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyn country=no_country_set disabled=no frequency-mode=superchannel radio-name=KK7AMW/Issaquah-Tiger scan-list=HamWAN ssid=HamWAN \
    wireless-protocol=nv2
/interface list
add name=WAN
add name=LAN
/interface wireless channels
set [ find default=yes ] supplicant-identity=MikroTik
/snmp community
set [ find default=yes ] addresses=44.24.240.0/20 name=hamwan
/system logging action
set 3 remote=44.24.244.8
/interface list member
add interface=wlan1 list=WAN
add list=LAN
/ip address
add address=192.168.86.53/24 interface=ether1 network=192.168.86.0
/ip dhcp-client
add disabled=no interface=wlan1
/ip dns
set servers=192.168.86.9
/ip firewall mangle
/ip route
add distance=1 gateway=192.168.86.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=222
set api disabled=yes
set api-ssl disabled=yes
/snmp
set contact="#HamWAN-Support on irc.freenode.org" enabled=yes location=47.516944,-122.0452
/system clock
set time-zone-name=America/Los_Angeles
/system identity
set name=KK7AMW-Issaquah
/system logging
add action=remote topics=info
add action=remote topics=warning
add action=remote topics=error
/system ntp client
set enabled=yes primary-ntp=44.24.244.4 secondary-ntp=44.24.245.4
/system routerboard settings
set boot-device=try-ethernet-once-then-nand
