On 2014-03-12 22:21, Bart Kus wrote:
/interface
wireless export verbose
[admin@AE7Q-Paine] > /interface wireless export
verbose
# jan/02/1970 00:40:00 by RouterOS 6.10
# software id = LTNR-CTND
/interface wireless channels
add band=5ghz-onlyn comment="Cell sites radiate this at 0
degrees (north)" \
disabled=no extension-channel=disabled frequency=5920
list=HamWAN name=\
Sector1 width=5
add band=5ghz-onlyn comment=\
"Cell sites radiate this at 120 degrees (south-east)"
disabled=no \
extension-channel=disabled frequency=5905 list=HamWAN
name=Sector2 width=\
5
"Cell sites radiate this at 240 degrees (south-west)"
disabled=no \
extension-channel=disabled frequency=5890 list=HamWAN
name=Sector3 width=\
5
set [ find default=yes ] authentication-types=""
eap-methods=passthrough \
group-ciphers=aes-ccm group-key-update=5m
interim-update=0s \
management-protection=disabled
management-protection-key="" mode=none \
mschapv2-password="" mschapv2-username=""
name=default \
radius-eap-accounting=no radius-mac-accounting=no \
radius-mac-authentication=no
radius-mac-caching=disabled \
radius-mac-format=XX:XX:XX:XX:XX:XX
radius-mac-mode=as-username \
static-algo-0=none static-algo-1=none
static-algo-2=none static-algo-3=\
none static-key-0="" static-key-1="" static-key-2=""
static-key-3="" \
static-sta-private-algo=none
static-sta-private-key="" \
static-transmit-key=key-0
supplicant-identity=MikroTik tls-certificate=\
none tls-mode=no-certificates unicast-ciphers=aes-ccm
wpa-pre-shared-key=\
"" wpa2-pre-shared-key=""
/interface wireless
set [ find default-name=wlan1 ]
adaptive-noise-immunity=none allow-sharedkey=\
no antenna-gain=0 area="" arp=enabled band=5ghz-a/n
basic-rates-a/g=6Mbps \
bridge-mode=enabled channel-width=20/40mhz-ht-above
compression=no \
country=no_country_set default-ap-tx-limit=0
default-authentication=yes \
default-client-tx-limit=0 default-forwarding=yes
dfs-mode=none \
disable-running-check=no disabled=no
disconnect-timeout=3s distance=\
dynamic frame-lifetime=0 frequency=5180
frequency-mode=superchannel \
frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0
ht-amsdu-limit=8192 \
ht-amsdu-threshold=8192 ht-basic-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
ht-guard-interval=any \
ht-rxchains=0
ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,\
mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,\
mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23"
ht-txchains=0 \
hw-fragmentation-threshold=disabled
hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=7
interworking-profile=disabled \
l2mtu=2290 mac-address=D4:CA:6D:54:B4:F5
max-station-count=2007 mode=\
station mtu=1500 multicast-buffering=enabled
multicast-helper=default \
name=wlan1-gateway noise-floor-threshold=default
nv2-cell-radius=30 \
nv2-noise-floor-offset=default nv2-preshared-key=""
nv2-qos=default \
nv2-queue-count=2 nv2-security=disabled
on-fail-retry-time=100ms \
periodic-calibration=default
periodic-calibration-interval=60 \
preamble-mode=both proprietary-extensions=post-2.9.25
radio-name=\
AE7Q/MillCreek-Paine rate-selection=advanced
rate-set=default scan-list=\
HamWAN security-profile=default ssid=HamWAN
station-bridge-clone-mac=\
00:00:00:00:00:00 supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
tdma-period-size=2 \
tx-power-mode=default update-stats-interval=disabled
wds-cost-range=\
50-150 wds-default-bridge=none wds-default-cost=100
wds-ignore-ssid=no \
wds-mode=disabled wireless-protocol=nv2
wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1-gateway
manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mb\
ps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17\
,HT20-0:17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT2\
0-7:17,HT40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:\
17,HT40-7:17"
/interface wireless nstreme
set wlan1-gateway disable-csma=no enable-nstreme=no
enable-polling=yes \
framer-limit=3200 framer-policy=none
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100
audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00
frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name=""
memory-limit=10 \
multiple-channels=no only-headers=no
receive-errors=no streaming-enabled=\
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes
receive-errors=no
