When Bart first proposed the HamWAN concept to various amateur radio forums, he observed that radio repeater sites would be beneficial to building the network.  It was pointed out that many of those sites provide space on a discounted or gratis basis for amateur radio purposes only (often in support of public service/emergency communications), and the repeater operators would likely loose their sites or start having to pay commercial rates.  Also, using 44.x.x.x routable addresses come with an amateur radio requirement.  In addition, running part 97 has greater transmitter power flexibility.
So, the network could be rebuilt using non Part 97 compliance, but new address space would be required (or a giant NAT infrastructure for IPv4) as well as re-negotiating site rentals.
So, unless those steps are undertaken, the network is under Part 97 rules for segments running in the US and its territories.
However, if Kent wanted to use the published HamWAN engineering work to build a similar WISP system, with associated costs, that is a possibility.
John D. Hays
Edmonds, WA
K7VE
