I am running a DynaDish5 mounted on a 20' mast LOS to Haystack 28.02 miles.
My location is only 3.8 miles from Paine but terrain is in the way.
73,
Drew, KG7SXF
Sent via the Samsung Galaxy S7 active, an AT&T 4G LTE smartphone
Date: 5/28/21 9:52 AM (GMT-08:00)
To: psdr <psdr@hamwan.org>
Hey everyone!
