Are these commands correct for modems which already have the 5-in-5 set of channels programmed?  Will it needlessly duplicate those channels?  What if they aren't named "Sector[123]" before I start applying this set of commands?
On 8/2/2014 10:49 AM, Tom Hayward wrote:
We will be switching the network from the 5 MHz channel plan to the 10 MHz channel plan. This affects sectors and client nodes. Client nodes that are live on the network and have shared administration enabled will be updated automatically. Other clients will need to update their own channel list. With the following channels configured in your modem, it will scan for the new channel as soon as the old channel disappears:
/interface wireless channels
# Current 5 MHz plan
add band=5ghz-onlyn comment="Cell sites radiate this at 0 degrees (north)" frequency=5920 list=HamWAN name=Sector1 width=5
add band=5ghz-onlyn comment="Cell sites radiate this at 120 degrees (south-east)" frequency=5905 list=HamWAN name=Sector2 width=5
add band=5ghz-onlyn comment="Cell sites radiate this at 240 degrees (south-west)" frequency=5890 list=HamWAN name=Sector3 width=5
# New 5 MHz bandwidth in 10 MHz channel plan (first channel is identical to old 5 MHz plan)
# New 10 MHz bandwidth in 10 MHz channel plan
For optimal performance, some sectors will continue to use 5 MHz bandwidth on the new 10 MHz-plan center frequencies. Add all the above channels to ensure your modem will connect in this situation.
This change will be implemented in 7 days, August 9th. Please update your configuration before then for a smooth transition.
