The only instruction I skipped was this one (step 14), due to the fact that every time I issue it, I lose connection to the modem I'm trying to set up ;-) ... the way I'm setting things up is by having a direct connection to my laptop via an ethernet cable plugged into the modem (a MikroTek DynaDish 5):
/ip address
remove [find]
You might be having trouble pinging my site because I fussed around with it and probably screwed it up.  I'm going to do a full reset and try again.
Here is the full script I use for setting things up.  I add the ssh keys for remote logging later, when I can get a net connection (which only happened once when I was accidently going through my home router):
/system identity set name=K7XST-Gold
/user set admin password=[redacted]
/user
add group=full name=eo password=JbLztDvlT7SRjPhv
add group=full name=NQ1E password=JbLztDvlT7SRjPhv
add group=full name=nigel password=JbLztDvlT7SRjPhv
add group=full name=osburn password=JbLztDvlT7SRjPhv
add group=full name=tom password=JbLztDvlT7SRjPhv
add group=full name=KG7OZZ password=JbLztDvlT7SRjPhv
add group=full name=ryan_turner password=JbLztDvlT7SRjPhv
add group=full name=ve7alb password=JbLztDvlT7SRjPhv
add group=read name=monitoring password=JbLztDvlT7SRjPhv
/system routerboard settings set boot-device=try-ethernet-once-then-nand
/system logging action set 3 bsd-syslog=no name=remote remote=44.24.244.8 remote-port=514 src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto target=remote
/system logging add action=remote disabled=no prefix="" topics=info
/system logging add action=remote disabled=no prefix="" topics=warning
/system logging add action=remote disabled=no prefix="" topics=error
/snmp set enabled=yes contact="#HamWAN on irc.freenode.org"
/snmp community set name=hamwan addresses=44.24.240.0/20 read-access=yes write-access=no numbers=0
/system ntp client set enabled=yes primary-ntp=44.24.244.4 secondary-ntp=44.24.245.4
/ip firewall filter remove [find dynamic=no]
/ip firewall mangle
/ip dhcp-server
remove [find]
/ip dhcp-server network
remove [find]
/ip dns
set allow-remote-requests=no
/interface wireless channels
/interface wireless set 0 radio-name="K7XST/Ballard-Gold"
/snmp set location=47.677622,-122.404322
/interface wireless
set 0 disabled=no frequency-mode=superchannel band=5ghz-onlyn mode=station scan-list=HamWAN ssid=HamWAN wireless-protocol=nv2
/ip dhcp-client
add add-default-route=yes dhcp-options=hostname,clientid disabled=no interface=wlan1
/ip dhcp-client
add add-default-route=no use-peer-dns=no dhcp-options=hostname,clientid disabled=no interface=ether1
On Sat, Jun 3, 2017 at 9:04 AM, Tom Hayward <tom@tomh.us> wrote:
On Fri, Jun 2, 2017 at 10:58 PM, Dave Stewart <dstewartgo@gmail.com> wrote:
> Nope -- although I have an IP coming from Gold Mountain (apparently), my
> internet was coming from my local connection.  If I plug straight into the
> model over ethernet from my computer (instead of having the ethernet
> connected to my home internet router), I'm still not able to hit the net.
The basic instructions don't cover redistribution to your LAN. If you
just want to plug in directly, you can do this:
https://hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configuration.html#integrating-hamwan-into-your-lan
And there's a link there to a page with some more complex schemes.
But back up a minute, there's something really odd with your
connection. You have a decent signal into Gold-S2, have a DHCP address
assigned, but can't be pinged. Did you set up some funky firewall
rules? Any deviation from the instructions?
Tom
