After hours of debugging, I got this 20MHz single-polarity link moving up to 55Mbit.  A high resolution spectrum analysis on both sides did indeed show a better frequency to use for the link.  Spectrum analysis captures here:
https://imgur.com/a/4H7GB
There was also an IP conflict between two modems @ Capitol Park.  The conflicting IP has been removed from CapitolPark-S3.
The QueenAnne modem used for the link is not one used anywhere else on the network.  It's a very low-end modem, and as a result it was having CPU/RAM starvation issues when running our regular diagnostic tools, which lead to out-of-memory conditions and kernel crashes.  A different test methodology had to be used to verify the link speed (testing through the modem, instead of to the modem).
The modem that links QueenAnne with the Westin building (on the QueenAnne side) had a mis-configured OSPF router-id.  This was fixed.
I'm still seeing weird routing decisions being made by OSPF.  These are triggered by our point-to-point route entries (44.24.242.0/24 space).  More research needs to be done here, and perhaps a re-write of how we define point-to-point interface addresses.  Any OSPF experts in the house?
I also discovered R1.QueenAnne was still vulnerable to hacking due to a mis-configuration of its control software.  It missed the updates that were sent out to the whole network.  This has been fixed now.  R1.QueenAnne also didn't have the diagnostic bandwidth-server setup correctly.  This was fixed.
With the CapitolPark-QueenAnne link performing well now:
[eo@CapitolPark-QueenAnne] /system resource> /tool bandwidth-test 44.24.241.81 direction=both
                status: running
              duration: 57s
            tx-current: 28.0Mbps
  tx-10-second-average: 28.4Mbps
      tx-total-average: 27.5Mbps
            rx-current: 27.6Mbps
  rx-10-second-average: 28.0Mbps
      rx-total-average: 27.0Mbps
          lost-packets: 288
           random-data: no
             direction: both
               tx-size: 1500
               rx-size: 1500
its OSPF config has been reset to a normal preference level, so that packets no longer try to avoid that link as they are routed through the network.  This link can be sped up by upgrading to a dual-polarity modem @ CapitolPark.
While testing if the OSPF hop cost was being calculated correctly in the Beacon-Haystack-QueenAnne RF link (they both connect to the same dish @ Haystack), I discovered a mis-config on the Haystack.Beacon modem (bad LAN IP binding) which was preventing it from bringing up OSPF on its LAN interface.  This was fixed and that modem should act like an actual router now, moving traffic.
During the same Beacon testing, I was reminded that our Baldi-Beacon RF link sucks.  It was optimized for speed to Tukwila, which is now gone, so a trip needs to be scheduled to Baldi to rotate the dish a few degrees north and get that link going strong.
I normally wouldn't send this kind of verbose email to psdr@, but I hope it's illuminating as to the type and extent of work required to keep this network running well.
