Good Afternoon,
Name here is Andy,kf7vol. I have been helping a series of ham get the necessary gear as well as configure and install here in the county. I wanted to reach out to your team and see if there was anything else needed once I get these sight set up on your network.
One item that we haven't been doing and I would like to do is get them posted to your network map. At this point I have four that I would like to get uploaded.
I see that someone had a URL to access the device through a web portal. Do these have to be created on your end?
While we are here I was wondering if your team had an antenna pointing solution other than looking at the signal in winbox? That method does work I just wanted to make sure there wasn't a better way out there.
Sorry for the baroque of questions I just felt it was high time that I reach out and make sure I was doing a proper job of setting up these sights.
Thank you for your time!
Andy Sayler, Head Monkey | Keyed Up/Oil Can Garage.
Down The Street | Lynden, WA
98264 | mobile (360) 319-7417
