On Sun, Feb 14, 2016 at 5:33 PM, Daniel Ransom via PSDR <
psdr@hamwan.org> wrote:
> I installed the new MikroTik MIMO radio and Ubiquiti panel antenna in the
> tree mount at my backyard fence (where I have LOS to Gold Mountain). My
> signal is 6 dBm better, with increased signal-to-noise ratio, over the
> QRT-5. (The QRT-5 moves to the South Kitsap School District bus barn for
> Emcom use.)
> The panel antenna has a 2-degree downtilt for mounting on a high site. So,
> for my low-site location I turned it upside down. See photos.
> I have attached a Winbox capture.
> 73 from Dan at K7MM
Dan,
This is great! I did not expect your sector antenna to have such favorable improvement over the QRT-5. I hope the QRT-5 performs well in its new home.
I am curious if a Poynting grid antenna could be aimed precisely enough from your tree mount to gain a few more dB.
Here's how the improvement looks on the graph (the gap is the time it took for me to point the monitoring at your new IP address):
By the way, since adding SNMP graphing for your node, your link status is now noted on the coverage map.
