Resent with my correct eMail address ...
On 2014-04-10 18:56, Dean Gibson
wrote:
On 2014-04-10 18:27, Bart Kus
wrote:
>traceroute
44.24.240.173
traceroute to 44.24.240.173 (44.24.240.173),
30 hops max, 38 byte packets
1 209.59.211.184 (209.59.211.184) 0.172
ms 0.075 ms 0.062 ms
17 44.24.242.19 (44.24.242.19) 95.778 ms
98.257 ms 95.279 ms
18 44.24.242.10 (44.24.242.10) 142.098 ms
103.353 ms 148.017 ms
19 44.24.240.132 (44.24.240.132) 137.942
ms 112.522 ms 113.787 ms
20 * * *
21 * * *
Nope, that shouldn't be. The network correctly routed your
packets to the right sector @ Paine, and then failed on the
very last hop in communicating with your modem? Depending on
where the trace was originating from and the state of your
modem's routing table at the time, your modem may have had
different ideas about how to reply. Or, you might have been
disconnected at the time?
Where are these following traces from? The modem? Was there
a specific source IP used?
The trace came from my computer on the Internet at
209.59.217.159, with the exact command you see above. Are you
sure that 44.24.240.132 is the right sector?
