Thanks for the encouragement! I may have some tree issues from my roof to hit Tiger. The picture is from my neighbor who has a great view. I thought it would be an easier starting point.
I was running the scan command and received no results. Going to try Haystack next, seems like I have a good view of it from my roof.
On Sat, Sep 11, 2021 at 7:07 PM Dylan Ambauen <dylan@ambauen.com> wrote:
Have you tried
/interface wireless scan 0
It should show Hamwan results unless you have an error in your config. Most people are jealous of your Line of sight. This setup is going to work great for you. You are almost there.
Dylan Ambauen
KI7SBI
On Sat, Sep 11, 2021, 16:58 Paul Sundquist <psundquist@foxhill.org> wrote:
New install on Squak Mountain Issaquah and unable to find any signal on Tiger Mountain. I’m 3.5 miles away west and a little north of the tower on Tiger.
Clear line of sight. Please validate with the tower picture attached.
Installed the following:
MikroTik mANT30 PA parabolic dish antenna 5GHz 30dBi MTAD-5G-30D3-PA
Mikrotik BaseBox 5 RB912UAG-5HPnD-OUT 5GHz Outdoor Wireless AP Gigabit USB OSL4
Questions:
Q1) Is the antenna tower on the right in the picture the right site?
Q3) I was watching the signal strength on the routerboard while running "/interface wireless scan 0”. Nothing showed up on the terminal session and no signal strength LED’s lit up. I moved it left to right and adjusted azimuth each time I stopped.
Q4) How long should you wait to acquire the signal between each time you move it?
Q5) Is there anything like the signal strength tones aiming a DirecTV dish?
Q6) Any other ideas. My exported configuration is below and I’ve successfully completed every step listed here: https://hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configuration.html
Thanks for your help!
-Paul KK7AMW
[admin@KK7AMW-Issaquah] > export
# sep/08/2021 16:57:46 by RouterOS 6.48.4
# software id = H1Z0-P9F3
# model = 912UAG-5HPnD
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyn country=no_country_set disabled=no frequency-mode=superchannel radio-name=KK7AMW/Issaquah-Tiger scan-list=HamWAN ssid=HamWAN \
    wireless-protocol=nv2
/interface list
add name=WAN
add name=LAN
/interface wireless channels
set [ find default=yes ] supplicant-identity=MikroTik
/snmp community
set [ find default=yes ] addresses=44.24.240.0/20 name=hamwan
/system logging action
set 3 remote=44.24.244.8
/interface list member
add interface=wlan1 list=WAN
add list=LAN
/ip address
add address=192.168.86.53/24 interface=ether1 network=192.168.86.0
/ip dhcp-client
add disabled=no interface=wlan1
/ip dns
set servers=192.168.86.9
/ip firewall mangle
/ip route
add distance=1 gateway=192.168.86.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=222
set api disabled=yes
set api-ssl disabled=yes
/snmp
set contact="#HamWAN-Support on irc.freenode.org" enabled=yes location=47.516944,-122.0452
/system clock
set time-zone-name=America/Los_Angeles
/system identity
set name=KK7AMW-Issaquah
/system logging
add action=remote topics=info
add action=remote topics=warning
add action=remote topics=error
/system ntp client
set enabled=yes primary-ntp=44.24.244.4 secondary-ntp=44.24.245.4
/system routerboard settings
set boot-device=try-ethernet-once-then-nand
