You can do a bit more debugging here to
bridge the gap between "config upload" and "connections don't
work". The router has a nice "/tool sniffer quick" utility
built-in. Try it with the arguments "interface=all
ip-protocol=tcp port=26" and launch a connection in from the
outside world. You should be able to see everything going on,
from the original packet coming in (or not), to it getting
translated and sent to your server (or not), to your server
replying (or not), to the un-NAT and retransmission (or not).
Somewhere along the line you'll spot the root of the problem. I
don't know what it is, as the config looks fine to me.
Oh, and screen width DOES matter. I believe if your window isn't
wide enough (eg: just 80 columns) it'll omit MAC address details.
So, max your window before running the sniffer. Either that or
use the winbox GUI sniffer.
Please report back!
On 04/03/2014 05:17 PM, Dean Gibson AE7Q wrote:
Objective: When an external (ie, wlan) connection is attempted to
port 26 on the radio, forward that traffic ("destination NAT") to
a computer on my internal LAN.
Firewall rules in the radio (rules #3 & #7 in the filter
chain, and rule #1 in the NAT chain, have been inserted by me):
/ip firewall filter print
Flags: X - disabled, I - invalid, D - dynamic
0 ;;; default configuration
chain=input action=accept protocol=icmp
src-address=44.0.0.0/8
1 ;;; default configuration
connection-state=established
2 ;;; default configuration
chain=input action=accept connection-state=related
3 chain=input action=accept protocol=tcp
in-interface=wlan1-gateway dst-port=26
4 ;;; default configuration
chain=input action=drop in-interface=wlan1-gateway
5 ;;; default configuration
chain=forward action=accept
6 ;;; default configuration
chain=forward action=accept connection-state=related
7 chain=forward action=accept protocol=tcp
8 ;;; default configuration
chain=forward action=drop connection-state=invalid
/ip firewall nat print
chain=srcnat action=masquerade to-addresses=0.0.0.0
out-interface=wlan1-gateway
1 chain=dstnat action=dst-nat
to-addresses=192.168.0.250 protocol=tcp
I use the same technique on my Linux boxes, and it works fine
(albeit iptables is slightly different). However, when accessing
my radio from an external IP address, no connection is made (times
out). If I change the dstnat rule action to "accept", the
connection is refused. The logs for port 26 on the target device
(192.168.0.250) show no connection attempt. In the (default)
srcnat chain, "action=masquerade" implies NATting on the return
trip (into the LAN). The same thing needs to happen in a dstnat
chain, but I don't see a way to do that; I'm "assuming" that the
OS automatically does that. When doing DNAT on Linux, I have to
do that manually, with the same rule in the "PREROUTING" and
"OUTPUT" NAT chains, but those chains don't exist in my radio.
Ideas welcome (note that "action=masquerade" is not valid in a
dstnat chain).
