Well yeah, you can't have ping without arp first, unless you configure static arp entries. :)
So it looks like the protocol does support 1/2 FEC, and also enforces an FCS (CRC). The FEC starts after clock recovery and frame synch, which is optimal.
Forget the FM receive thing, all I really wanted to know is what the SNR of the 1.2GHz signal you get from Paine? If the ID-1 doesn't tell you this, an RTL-SDR should. Does the link work in 4.8kbit mode? I'm assuming you have both sides set for 128kbit right now.
On 5/28/2014 7:20 PM, Dean Gibson AE7Q wrote:
See http://www.arrl.org/files/file/D-STAR.pdf - pages 3-5 describe the DD-mode (data) packet.
The ID-1 apparently doesn't know whether or not the Ethernet frame is corrupt. From the TX/RX lights for both the radio and the Ethernet connection, it appears that every received packet from one end, goes out the other.
When conditions are right and I receive about 10% of the packets from a PING (like last Monday), it seems clear from observed behavior that once an ARP response is received, then quite a few PINGs get through. I haven't tried listening on FM to a DD packet, but I can try that on Thursday, when I am at the DEM. I'm not sure what the point of that would be, though.
On 2014-05-28 17:12, Bart Kus wrote:
This is some really broad strokes. Are there specifics on ID-1 protocol / framing somewhere?
On 5/27/2014 4:59 PM, John D. Hays wrote:
ID-1 simply encapsulates an Ethernet frame behind a D-STAR header. The header has some correction, but the Ethernet frame is not corrected by D-STAR.
On Tue, May 27, 2014 at 4:28 PM, Bart Kus <me@bartk.us> wrote:
There's no protocol I'm aware of that implements these features on top of ID-1. You'd need the ability to receive corrupt frames from the ID1 to allow the use of FEC. How does the ID1 handle corrupt frames? Is there a CRC or something in the framing? For ARQ, you could keep the TX retrying until it hears an ACK or times out. Custom software would be needed, or perhaps pppd can do such tricks, I dunno.
Did you hear any signal when you listened with an FM receiver? Can you use an RTL-SDR or equivalent to see if there's any signal present?
On 5/24/2014 8:36 PM, Dean Gibson AE7Q wrote:
So, my next question: Is there an available tunneling protocol that employs those features?
Note that with the ID-1 in the one watt setting (same omni antenna), I can use the 1.2GHz KB7CNN repeater 35 miles away on East Tiger mountain, with no noise in the FM signal. The link to Paine (5 miles away) was tried at max power (ten watts) on both radios. I tried two different frequencies (that's the beauty of being able to control both radios from one location!): 1.250GHz and 1.249GHz (I listened on both in FM mode), with no significant difference. So, in my opinion, it's a path problem.
Wow that sucks. :( Is the signal level just too low? Is it a matter of interference?
And yeah, I can confirm that the microwave stuff we use includes both FEC (at up to 1/2 rate) and an ARQ system (look at "hw-retries" setting). These features are common to all WiFi systems too, and they're just carried over into our NV2 TDMA system.
- We have installed a gateway (Linksys BEFSR41) between the ID-1 and the internal ARES/RACES subnet (not 44.x.x.x) of the DEM.
- We have installed a Digi "AnywhereUSB" box to give us remote access to the ID-1's USB port, and thus remote control of the ID-1 radio. This not only allows multiple use of the ID-1 (which has useful 1.2GHz FM and digital voice modes as well as Ethernet data), but provides for remote frequency agility and a diagnostic capability. This works beautifully (eg, to search for and use a low-noise frequency)!
Unfortunately, what does not work very well, is the RF portion of the connection. PINGs failed at a rate of over 99% when using the 1.2GHz antenna at the 70 ft level on the tower, so we swapped the antenna with the one used for the Icom 1.2GHz repeater (which wasn't seeing any action anyway) at 100 ft. That made a "dramatic" improvement, as PINGs now only fail at a 98% rate (depends upon the time of day, etc)!
- On 1.2GHz, both antennas are omni-directional.
- At the DEM, the 1.2GHz antenna is now at the 100' level, whereas the 5.9GHz antenna is at 150'.
- At my home, the 1.2GHz antenna is about 10' above the 5.9GHz antenna, and it's on the same line-of-sight path.
The big difference, in my opinion? I'll bet that the wireless protocol used by the MikroTik radios includes an aggressive error correction and retry protocol, whereas the ID-1 is like a piece of Ethernet cable, and thus relies on the standard TCP/IP retry mechanism. The TCP/IP protocols, while "unreliable" in the technical sense of the term, require a higher overall reliability than a typical raw wireless connection.
What this says (and I'm a bit surprised to note this), is that sites considering using ID-1 radios for data communications, may find that even with the tighter siting requirements of 5.9GHz, that the latter may be more successful (whether or not part of HamWAN). In addition to being a lower-cost radio with a much higher data rate, the MikroTik radios offer a built-in router, which can obviate the need for a separate router.
ps: The callsign and digital code filtering features of D-Star that we previously discussed, are not available (greyed out in the software) for digital data mode. Huh? Another fine example of software of the "seven last words" of poor program design: "Why would you want to do that?"
