Hello John,
The key factor is if you have visibility to one of our sites. 5.9 GHz is very line-of-sight, a tree or two *might* work, lots of trees or a landform and it’s not going to get through. Since you’re downtown, we have occasionally seen bounces off of other buildings work, so you’ll want to try turning your dish in various directions to see what sort of signal you can get.
All of the client hardware we recommend is listed here: http://hamwan.org/Standards/Component%20Engineering/Client%20Hardware.html I would suggest you get a MIMO capable setup. More gain is better, so get the most you can within your budget. The downside to downtown is there is a lot of other wifi signals around. If you can afford it, a shielded setup like the second option in the list may help keep unwanted signals out.
Once you have the gear, the configuration is laid out step by step here: http://hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configuration.html We try to make that fairly easy to follow, but if there are issues, let us know.
Once you have those, it’s a matter of turning it on, and pointing it around to find your best signal. Once you have that, you’re good to go.
On Jun 7, 2018, at 12:13, John Spady <jspady@mac.com> wrote:
Hello friends,
I finally have formal approval from my condo board to install a non-penetrating roof mount on my condo building at 2801 1st Ave in downtown Seattle to access either the Beacon or Gold HamWAN signal and to bring it all the way down to our first floor club room where all our building ham operators can more easily access it.
I am now in the process of identifying the equipment I’ll need and making a plan. I am looking for HamWAN mentors who would be willing to review these plans and offer any suggestions for a smooth installation and appropriate equipment.
Please write to me privately at jspady AT mac DOT com or call me at 206-465-6963.
I appreciate any and all assistance.
Regards to all,
John Spady, WA7UAR, Seattle
