The shot to Capital Park from my house goes through quite a
few tree's in my immediate area. (All within a couple blocks
from me) When I originally installed the tower about 10 years
ago, I was able to see downtown from the top of it. Now I
can't, due to the trees of the neighbor directly behind me and
his neighbor.
That
said, I don't actually have the HamWAN antenna mounted on the
tower yet. I had to postpone that installation until my knee
heals up. (Had the meniscus repaired in my left knee last
week) Right now the antenna is mounted to a small mast at the
apex of the roof. (It is sharing the mast with a VHF/UHF
vertical)
I
thought that I'd posted links to these pictures before, but I
guess not.
The
difference in signal strength from the antenna being on the
deck railing to its current location is ~5 dB. The height
difference between the to location is about eight to ten feet.
When moving the antenna to the roof the first time, I had
originally installed it on a mast located at the far east side
of the roof. In this spot I could not hear CP at all. By
moving the antenna to the mast located in the center of the
house (which is about 20-25 feet west), the signal appeared
and has so far been the best location. I ordered another mast
mounting kit for the eve located at the far west side of the
house. When I'm feeling better I'll install it and see if the
signal improves again when moving west.
I
don't have many data points on the impact of wind on the
signal strength. I did check it on Sunday when a system blew
through which was causing the trees to noticeable move. But I
wasn't seeing much change in the signal strength. (maybe 1
db?)
