There's some confusion here, so allow
me to clear it up.
What Mike's talking about is a utility called Netinstall
http://wiki.mikrotik.com/wiki/Manual:Netinstall) that allows
recovery of truly crashed devices. "Truly crashed" means that
RouterOS is not booting. It doesn't scan for devices, it just
serves as a PXE server, and it's up to the devices to request a
PXE boot. The code that controls PXE booting is in a different
part of flash than the RouterOS itself, and does not depend on
RouterOS.
Winbox can indeed use a layer 2 protocol (called mac-winbox), and
it can also use IP (layer 3). Which protocol it uses depends on
the address (MAC vs IP) you tell it to connect to. However, it
doesn't provide the PXE flashing capability. If RouterOS is truly
crashed, Winbox won't work.
Another layer 2 protocol is mac-telnet. This is configured as a
separate service from mac-winbox on RouterOS. Recently we had a
case where mac-telnet was inaccessible (was not configured to
listen on any interfaces) but mac-winbox was set to its default of
listening on all interfaces. We were able to regain control of
the router by using the alternative layer 2 protocol.
In Dean's case, we don't know what he means by "dead". It could
be that the ethernet link is up and IP just stopped working. He
can try the 2 MAC protocols. If those fail, he can try the
Netinstall recovery.
On 5/4/2014 9:40 AM, Kenny Richards wrote:
