If you want to try it portable, I have used mine mounted on a tripod with good results. Makes for a large go-kit.
Here’s a link to the tripod I use: https://www.dxengineering.com/parts/mfj-1919ex
-Lionel
K7BIX
206-778-3368
Hamshack Hotline#: 5670
Sent: Monday, March 15, 2021 1:54 PM
To: Puget Sound Data Ring <psdr@hamwan.org>; Kenny Richards <richark@gmail.com>
Well, bad news. I have a wall of Douglas Fir at the end of the block between me and Capital Peak. I don't have a clear shot. I may set this station up at the Thurston County EOC for use in the radio room for Winlink traffic. My site is a no-go.
Phil Cornell
W7PLC
SHARES NCS590
Hybrid Gateway W7PLC
TCARES VP
On Monday, March 15, 2021, 12:49:39 PM PDT, Kenny Richards <richark@gmail.com> wrote:
Good luck,
Kenny, KU7M
Hi Phil,
As to trees, they are an absolute show stopper. You must have clear, visual, line of sight to the HamWAN site you are shooting to. Hopefully you will have that, or can achieve that, from where you plan to mount the dish. As to “just over them”, a microwave shot consists of the direct, pure line of sight, but also what is referred to as the Fresnel zone – a cigar shaped “balloon” around the pure line of sight. Items in the Fresnel zone (including trees) can reduce the amount of signal you have, so you may not get optimum performance, but some.
In your initial post you commented about how to balance between your regular internet and HamWAN for a Winlink node. My suggestion would be to just leave it on one (whichever one) as the norm, and only switch to the other if the one goes down. You can also acquire routers that include failover capability to automatically make that switch. You can go more advanced with load sharing and such between multiple connections, but that requires much better understanding of internet routing, and for a winlink node basic failover will serve your purpose.
Subject: [HamWAN PSDR] Newbie
OK, I figured out my problem and I now have Winbox talking to the radio and reporting status. I's not linking to anything since the antenna is still on the ground. How much configuration can I do before mounting it on my roof. The only question in my sight path may be some trees but I think I can aim just over them and get a signal. My friend Bruce/WA7BAM will be helping with the antenna installation on Wed afternoon. Making progress...
Phil Cornell
W7PLC
SHARES NCS590
TCARES VP
