Hello -- I'm trying to set up a connection, using the instructions here:
http://hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configuration.html
I'm getting all the way to the point where I try to do a tracert ("Connect" step 3), but nothing is coming through.
My monitor shows the following -- any ideas what I should do next?  Am I just not hitting the Gold Mountain node well enough?
[admin@K7XST-Gold] > /interface wireless monitor 0
                  status: connected-to-ess
                 channel: 5900/5/an
       wireless-protocol: nv2
                 tx-rate: 14.4Mbps-5MHz/2S/SGI
                 rx-rate: 1.6Mbps-5MHz/1S
                   bssid: E4:8D:8C:F1:6D:22
              radio-name: Gold-S2/K7WAN
         signal-strength: -76dBm
     signal-strength-ch0: -78dBm
     signal-strength-ch1: -80dBm
      tx-signal-strength: -71dBm
  tx-signal-strength-ch0: -73dBm
             noise-floor: -107dBm
         signal-to-noise: 31dB
                  tx-ccq: 54%
                  rx-ccq: 6%
   authenticated-clients: 1
        current-distance: 33
                wds-link: no
                  bridge: no
        routeros-version: 6.36
                 last-ip: 44.24.240.97
     notify-external-fdb: no
