Welcome to my world ;)
As I've expressed in the past, this is one
of the challenges that makes me excited about this
project. Making a network secure without encryption
isn't really something that's been done before. Several
protocols do support authentication and integrity
without secrecy, but I suspect they were
only implemented for things like compatibility testing.
The trick is going to be finding out how to take
advantage of that in a way that doesn't make it too
complicated for end-users to implement.
Because we're not going to encrypt traffic,
using anything password based won't do. A shared secret
would be okay except that it's hard to control, change
and keep secret (this is the method HSMM-MESH and
NW-MESH currently use to trust the OLSR announcements of
other users). I believe that the best option by far
would have to be a solution based on public/private key
pairs.
Here are the options I know of based on
layers of the OSI model:
Layer 6: SSL/TLS & SSH
It seems to me that SSH was designed with
secrecy as the main goal, while integrity and trust were
simply slapped on as an afterthought. While it appears
to be possible to use SSH with null (no) encryption, I
haven't been able to find any client or
server implementations that support it without code
modifications.
From the start, SSL was designed with the
idea that you need a way to establish trust with a
server you may be connecting to for the first time. The
actual encryption part of the protocol is modular and
it's easy to setup a server to use "null" as its cipher.
Unfortunately for us, most web browsers cripple support
for null ciphers because they assume nobody would ever
need that and they don't want users connecting to
"misconfigured" servers. So far I've only found two
browsers that support turning null ciphers back on in
their advanced settings (Firefox and Opera). A little
known/used feature of SSL/TLS is mutual authentication.
This is where the client also has a certificate and
private key so that trust can be established in both
directions. My testing has confirmed that this works,
but it may be too complicated to setup for both the
client and the server.
Layer 3: IPSec
Similar to SSL, IPSec has the ability to
provide authentication and integrity to traffic without
hiding its payload with encryption. This is the area
where my research is currently focused. I want to be
able to prove that it can be done in a way
that's hopefully easy for users to understand and
implement. The major advantage to this method is that
it's configured at the OS level and any client or server
program would be able to take advantage of it.
Layer 2: 802.1x
With the methods above, someone could still
generate illegitimate traffic over at least one RF
portion of network. In order to protect the link layer,
we could use 802.1x. Unfortunately, it only provides
authentication and does nothing about integrity. This
means that without encryption, it would be trivial to
impersonate another user on the link layer who is
already authenticated.
At this point, I believe that using 802.1x
on the RF links and enforcing rules that only allow
IPSec signed traffic to pass would meet the objectives.
There's also the added benefit that IPSec traffic
maintains its signature throughout the life of the
packet, so rogue users could be identified regardless of
where their traffic originated.
While this is an area where my geekdom
shines, I do not pretend to know it all. Therefore I
definitely encourage conversation on these topics as
long as it remains constructive. What do you think
about these approaches?
-Cory
NQ1E
