OK, I don't believe any of you cut down any trees on the 5.9GHz path to the SnoCo DEM near Paine field, but something changed:
Starting about a week ago, the signal levels have increased about 6dBm.  For the past several days I have had more or less a decent connection:
                  status: connected-to-ess
                    band: 5ghz-n-5mhz
               frequency: 5900MHz
       wireless-protocol: nv2
                 tx-rate: 2.2Mbps
                 rx-rate: 1.5Mbps
                   bssid: D4:CA:6D:7A:B8:07
              radio-name: Paine-S2
         signal-strength: -84dBm
     signal-strength-ch0: -84dBm
      tx-signal-strength: -79dBm
  tx-signal-strength-ch0: -79dBm
             noise-floor: -118dBm
         signal-to-noise: 34dB
This is in marked contrast to just two weeks ago, when I couldn't hold a connection at all (as was typical through the entire winter).
Kenny, I thought you told me your connection has been poor lately.  Have you checked in the past week?
On 2015-02-17 13:36, Dean Gibson AE7Q wrote:
Now, if I can just get a couple of you to cut down some trees (not on my property) in the middle of the night, my appreciation would be unbounded ...
