Hi Jamie,
Thanks again for this information. I been weighing some options and I recently plotted the RF path and took at look at the terrain and obstructions. The LHG XL HP5 has a beamwidth of 6.4 degrees, so I drew a plot on a map. As you can see, I've got some trees in the way for the first mile. After I get to the line in red, the elevation drops and I'm completely clear all the way to Haystack. I'm planning on mounting my dish outside on a pole and it will have an elevation of about 35 feet. This should make me clear of rooftops and most obstructions, but I've still got some trees in the way as you can see from my chart. Total distance will be 34 km, elevation change will be +998m, so an upward angle of 1.68 degrees.
In your opinion, or if anyone else has more thoughts on this, do you think that the treetops will be a showstopper at that distance or do you think the LHG XL HP5 dish can punch through and get at least 1 Mbits? Any way that I could accurately guess, or do I just need to set it up and find out?
Jesse
KJ7YLS
On May 28, 2021, 12:00 PM, Jamie Hughes < wa7jh@outlook.com> wrote:
Hi Jessie,
I’ve seen the responses so far and I think you deserve a little more.
5 GHz requires unobstructed Line of Sight (LoS) this means if you can’t see it, you can’t work it (reliably). While it is wireless and penetrates through things, the process for going through things causes signal distortion, degradation, attenuation, fading, and multipath. All bad things when dealing with data over the air. Also, not sure what your planned use would be, but HAMWAN isn’t your typical internet service provider.
Out of your options #1 seems the best, but if those windows are tinted, then, you are SOL.
The LHG HP5 is a great choice: MikroTik Routers and Wireless - Products: LHG HP5
You will likely desire a mounting option: MikroTik Routers and Wireless - Products: solidMOUNT
I recommend Streakwave
MikroTik RBLHG-5HPnD-XL 5GHz LHG 27dBi 802.11an 2x2 ROW (streakwave.com) This is the high-power version for $81
MikroTik solidMOUNT Advanced Pole Mount Adapter for LHG (streakwave.com): Mount for $27.55
You will need to email a copy of your amateur license to William Book William.Book@streakwave.com to prove you’re a ham.
Super easy to work with. Shipping is where they will get you, so be ready for that.
My club runs 3 dishes, all purchased from Streakwave with the help of Bill.
Feel free to reach out direct if you need anything else.
Jamie Hughes
WA7JH
Phone: (360) 340-8886
Sent: Friday, May 28, 2021 9:51 AM
To: psdr <psdr@hamwan.org>
Hey everyone!
Jesse
KJ7YLS
