Hello Again.
Even though I can't see in that direction, I can hit the Gold Mountain
2m Repeater from inside my apartment with an at 1 watt and the signal
from the repeater here is full quieting. Should this give me any
significant hope that I might have some luck with a path at 5+ Ghz?
Just a thought...
Thanks again.
Regards All.
73
-Grace
KC0BTM
NNNN
z
On 4/23/2017 11:02 PM, Tom Hayward wrote:
> On Sun, Apr 23, 2017 at 10:34 PM, Grace B Thomson <gracebt@eskimo.com> wrote:
>> Hi Bart,
>> I am looking at the L-Com HG5822EG antenna with the RBMetal 5SHPn. Do
>> You think this is a workable configuration:
>> http://www.ispsupplies.com/L-Com-HG5822EG
>> http://www.ispsupplies.com/MikroTik-RouterBOARD-RBMetal- 5SHPn
> That antenna is only 22 dBi. For a few more dB and MIMO support (also
> cheaper), you could get a DynaDish:
> https://www.streakwave.com/itemdesc.asp?ic=DynaDishG- 5HacD
> Or, like Bart mentioned, the QRT-5 is good for window shots.
> But if you can't see a site out the window, neither will likely work
> from that location.
> Tom
