Yep just use fetch with mpde=ftp and setup ftp server on windows box, problem solved
On Wed, Nov 23, 2022 at 12:57 AM Tom Hayward <tom@tomh.us> wrote:
Sounds like you just need /tool fetch.
https://wiki.mikrotik.com/wiki/Manual:Tools/Fetch
The blacklist script is a thorough example: https://github.com/kd7lxl/blacklist-service/blob/master/block-address.rsc
On Tue, Nov 22, 2022, 19:00 Rob Martin via PSDR <psdr@hamwan.org> wrote:
I am trying to achieve something using RouterOS scripting, and I'm hoping that here I might find the appropriate expertise.
From a script running in a Mikrotik router I wish to pull in a copy of a file from an attached Windows computer. The computer is on the same subnet as the router.
By way of illustration:
     A file called test.xxx exists on a Windows computer in the folder c:\aaa\
     I want a copy of this file to appear in the attached router /file list. This copy "event" could be either a push from the computer, or a pull from the router.
When using Winbox, this function is achieved easily using "drag and drop", but I need to automate the function.
Thanks.
K7QJ
Jamie Owens
