Wow that sucks.  :(  Is the signal level just too low?  Is it a matter of interference?
And yeah, I can confirm that the microwave stuff we use includes both FEC (at up to 1/2 rate) and an ARQ system (look at "hw-retries" setting).  These features are common to all WiFi systems too, and they're just carried over into our NV2 TDMA system.
