The current plan is to block all unsolicited incoming traffic from the internet on the edge routers before it gets to the RF portions of the network.  However, we don't want to do that until we have automation in place to maintain those rules and until we have a self-service way for you to poke holes in that configuration should you want to allow incoming traffic from the world to one of your IP addresses.  If you want to block traffic from all sources (including other hams), then adding firewall rules to your own device is the correct way to accomplish that.
The rules are well established for auto-patches that connect voice repeaters to the PSTN.  Even incoming telephone calls are allowed as long as they are "expected" by the ham.  Because the parallels between these systems are fairly clear, the plan above puts us in the best position to make sure our users are able to maintain their part 97 compliance.
On Sat, Mar 15, 2014 at 11:25 PM, Dean Gibson AE7Q <hamwan@ae7q.net> wrote:
OK, after seeing the number of "random" IP addresses hitting the radio from outside the 44.0.0.0 net, I didn't like the fact that the firewall filters were removed in the web site's suggested configuration, so I decided to start from scratch.  I learned a couple things ...
# -- Restore the radio to a factory fresh state --
/system reset
# === At this point you must connect via MAC address ===
/user set admin password="This is not it ..."
/console clear-history
/system identity set name="CALL-Paine"
/ip
dns set allow-remote-requests=no
address remove [find]
/ip firewall mangle
add action=change-mss chain=output  new-mss=1378 protocol=tcp tcp-flags=syn tcp-mss=!0-1378
/ip dhcp-server
remove [find]
network remove [find]
/ip dhcp-client
add  add-default-route=no  dhcp-options=hostname,clientid disabled=no interface=ether1 use-peer-dns=no
# -- The following is already configured --
#add add-default-route=yes dhcp-options=hostname,clientid disabled=no interface=wlan1
# -- Do the following if you need to move the radio to a different network --
/system shutdown
# === At this point you can connect via IP address ===
/system logging
action set remote bsd-syslog=yes remote=my.lcl.log.svr remote-port=514 src-address=my.lcl.ether.ip syslog-facility=local1 syslog-severity=info
add action=remote disabled=no prefix="" topics=!debug,!snmp
Note that I have "bsd-syslog" set to "yes".  This appears to be necessary if you want a remote system to see "syslog-facility" and "syslog-severity" (the radio doesn't save/display those settings otherwise).
/system ntp client set enabled=yes mode=unicast primary-ntp=my.lcl.ntp.svr1 secondary-ntp=my.lcl.ntp.svr2
/interface wireless
channels add band=5ghz-onlyn comment="Cell site sector centered at 360 degrees" frequency=5920 list=HamWAN name="Sector300-060" width=5
channels add band=5ghz-onlyn comment="Cell site sector centered at 120 degrees" frequency=5905 list=HamWAN name="Sector060-180" width=5
channels add band=5ghz-onlyn comment="Cell site sector centered at 240 degrees" frequency=5890 list=HamWAN name="Sector180-300" width=5
/delay 5
set 0 radio-name="CALL/Location-Paine"
set 0 disabled=no frequency-mode=superchannel scan-list=HamWAN ssid=HamWAN wireless-protocol=nv2
/tool dns-update dns-server=my.lcl.dns.svr key="MD5 key ..." key-name=ddns ttl=3600 zone=ae7q.net name=hamwan-1 address=my.ham.wan.ip
monitor 0
I like my sector names better than just numbers...
These "scripts" (when altered) can just be pasted into a command window (otherwise the "/delay 5" above is not necessary).
Oh, I can sometimes connect through my CLOSED window, but that's not reliable enough for anything useful.
