I’m running a reliable connection Tacoma -> Haystack, and I consistently achieve over 10Mbs / 10Mbs download/upload speeds with very low latency under 20ms with a distance of over 85k / 52mi.
LOS is going to be the best factor in selecting a site for your setup.
73,
Wade W7ITL
On Fri, Mar 17, 2023 at 5:48 PM Nigel Vander Houwen <nigel@nigelvh.com> wrote:
To Tom’s point, the distance almost doesn’t matter. We’ve had links much farther than the 28 miles you’re looking at. You would of course want to select a client setup with the most gain possible for reliability, but almost universally if you can see it, you can connect.
> On Mar 17, 2023, at 17:34, Nick Kartsioukas <nick@explodinglemur.org> wrote:
> I can see nothing from my roof.  From my original mail, "For example it looks like I "only" need a 35' mast for Baldi, but at 28mi away I'm not sure I can get connected reliably, vs Beacon or Capitol Park which are much closer but I'd need at least a 66' mast thanks to local terrain and trees."  Local terrain and trees are a challenge here which is why I want to gather and simulate as much as I can before I try to do something that a simulation would rule out.
> On Thu, Mar 16, 2023, at 22:17, Tom Hayward wrote:
>> I can appreciate the desire to play around with the mapping tools and
>> coverage models. I have done a lot of that myself.
>> We've found that the most reliable predictor of coverage, aside from an
>> RF survey, is a pair of binoculars. Can you see the tower while
>> standing on your roof?
>> Tom KD7LXL
>> On Thu, Mar 16, 2023, 21:17 Nick Kartsioukas <nick@explodinglemur.org> wrote:
>>> Because I enjoy playing around with radio coverage mapping tools and want to have the closest representation of reality?
>>> I'm in an exceptionally non-optimal area for PSDR, so I want to have as much information as I can about required mast height and link budget for each site before I go actually installing anything.
>>> On Thu, Mar 16, 2023, at 15:45, Stephen Kangas wrote:
>>>> Nick, I'm not certain why precision matters here.  My experience
>>>> working with Bart & Doug assisting them putting up the Rattlesnake Mtn
>>>> sector is that they may deviate from the exact bearing only to provide
>>>> better coverage to the area below, avoiding obstacles and focusing on
>>>> the user community.  We're not talking really narrow beams here.  You
>>>> should be able to expect that if there is a sector antenna pointed to
>>>> your area that it is optimized for your chances of connection
>>>> regardless of how precise the sector antennas matches 0deg N bearing
>>>> offsets.
>>>> FWIW, Stephen W9SK
>>>> -----Original Message-----
>>>> From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Carl Leon
>>>> Sent: Thursday, March 16, 2023 3:16 PM
>>>> To: 'Puget Sound Data Ring' <psdr@hamwan.org>
>>>> Subject: Re: [HamWAN PSDR] Site details?
>>>> Those are the standard. I think there is one single sector site where
>>>> that varies, but am not certain.
>>>> Carl, N7KUW
>>>> From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Nick Kartsioukas
>>>> Sent: Thursday, March 16, 2023 9:51 AM
>>>> To: psdr@hamwan.org
>>>> Sorry, I phrased that part poorly.  Are all sectors aligned at
>>>> 0/120/240 when present, or do they deviate from those bearings?
>>>> On Thu, Mar 16, 2023, at 08:26, Doug Kingston wrote:
>>>>> Not all the cell sites have every sector.  If a cell site is on the
>>>>> side of a hill or has a large obstruction immediately adjacent, we
>>>>> omit the sector facing into the obstruction as it would not serve any
>>>>> useful purpose.
>>>>> We have tried to depict the available sector in the map on the
>>>>> website, but you may need to zoom in to see that detail.  If you have
>>>>> questions about particular sites, Feel free to contact me directly
>>>>> (dpk@randomnotes.org) or mail the netops@ list or ask on our IRC
>>>>> channel.
>>>>> -Doug-
>>>>> On Wed, Mar 15, 2023 at 9:15 PM Nick Kartsioukas
>>>>>> I've been able to find location info for most of the PSDR sites and antenna height info for some of them.  Do they all have sectors pointing 0/120/240 degrees relative to north?  Is there anywhere that has EIRP info?  I'm trying to see how tall a mast I need to get connected, and whether or not I can even make link for some of the sites.  For example it looks like I "only" need a 35' mast for Baldi, but at 28mi away I'm not sure I can get connected reliably, vs Beacon or Capitol Park which are much closer but I'd need at least a 66' mast thanks to local terrain and trees.
>>>>>> At the moment I'm using https://ispdesign.ui.com/ (which now has LIDAR data for buildings/trees!) and have also used RadioMobile Deluxe in the past.
>>>>>> Thanks!
>>>>>> _______________________________________________
>>>>>> PSDR mailing list
>>>>>> PSDR@hamwan.org
>>>>>> https://mail01.fmt.hamwan.net/mailman/listinfo/psdr
>>>>> PSDR mailing list
>>>>> PSDR@hamwan.org
>>>> PSDR mailing list
>>>> PSDR@hamwan.org
>>>> PSDR mailing list
>>>> PSDR@hamwan.org
>>>> PSDR mailing list
>>>> PSDR@hamwan.org
>>> PSDR mailing list
>>> PSDR@hamwan.org
>> PSDR mailing list
>> PSDR@hamwan.org
