Kenny and all,
One (hopefully final) set of comments regarding Blyn sector 3.
With sector antennae radiating 120 degrees wide, this means a sector 3 coverage of *roughly* 180 degrees through 300 degrees, given that sector 3 is pointed at 240 degrees. While a good chunk of that (sector 3) pattern would be covering forested land, it looks like a number of under-served (albeit small) communities along the hood canal, and along US 101, might be provided coverage by this sector, especially if the antenna were biased a few degrees counter-clockwise.
If we don't want to cover national park land, how about a 60 degree wide sector antenna for sector 3, pointing more toward 200 degrees or so? (a 170-230 degree "cone"). This would focus more of the RF footprint on populated areas. We could even cut the power in half going to that 60 degree antenna, resulting in the same effective radiated power but a bit less RF congestion in the "shack."
There is clearly no one "correct" path forward, and thanks for considering these comments and suggestions. As always, many thanks go to the people who show up, and put in the hours of work making HamWAN happen.
John KX7JM
