You're unlikely to make it to SnoDEM (Paine).  There's plenty of terrain in your way, as Drew points out.  You are likely to make it to Haystack with a tripod mounted on the roof, as shown in the signal path here:
Good luck!
On 5/28/2021 11:32 AM, kg7sxf wrote:
Jesse,
I am running a DynaDish5 mounted on a 20' mast LOS to Haystack 28.02 miles.
My location is only 3.8 miles from Paine but terrain is in the way.
73,
Drew, KG7SXF
Sent via the Samsung Galaxy S7 active, an AT&T 4G LTE smartphone
Date: 5/28/21 9:52 AM (GMT-08:00)
To: psdr <psdr@hamwan.org>
Hey everyone!
Jesse
KJ7YLS
