I'll give that a try later, going out for the day.
As for the passwords, oops!  The site says this should be fine, but to be sure, when I reset I'll generate new ones!
The passwords above are randomly generated in your browser, not stored anywhere, and will never be used. Any HamWAN access to your modem will be done with certificates.
On Sun, Jun 4, 2017 at 12:58 PM, Tom Hayward <tom@tomh.us> wrote:
Probably shouldn't post passwords for accounts with full
administrative rights publicly. On the bright side, I tried them and
they don't work ;-)
Your modem is acting like you have the ethernet and wireless
interfaces bridged. Can you show me the output of
/interface export?
If this is indeed the issue, I think this command will clean it up:
/interface bridge disable [find]
This will disconnect you, but you can reconnect.
Tom
On Sun, Jun 4, 2017 at 12:30 PM, Dave Stewart <dstewartgo@gmail.com> wrote:
> The only instruction I skipped was this one (step 14), due to the fact that
> every time I issue it, I lose connection to the modem I'm trying to set up
> ;-) ... the way I'm setting things up is by having a direct connection to my
> laptop via an ethernet cable plugged into the modem (a MikroTek DynaDish 5):
> /ip address
> remove [find]
> You might be having trouble pinging my site because I fussed around with it
> and probably screwed it up.  I'm going to do a full reset and try again.
> Here is the full script I use for setting things up.  I add the ssh keys for
> remote logging later, when I can get a net connection (which only happened
> once when I was accidently going through my home router):
> /system identity set name=K7XST-Gold
> /user set admin password=[redacted]
> /user
> add group=full name=eo password=JbLztDvlT7SRjPhv
> add group=full name=NQ1E password=JbLztDvlT7SRjPhv
> add group=full name=nigel password=JbLztDvlT7SRjPhv
> add group=full name=osburn password=JbLztDvlT7SRjPhv
> add group=full name=tom password=JbLztDvlT7SRjPhv
> add group=full name=KG7OZZ password=JbLztDvlT7SRjPhv
> add group=full name=ryan_turner password=JbLztDvlT7SRjPhv
> add group=full name=ve7alb password=JbLztDvlT7SRjPhv
> add group=read name=monitoring password=JbLztDvlT7SRjPhv
> /system routerboard settings set boot-device=try-ethernet-once-then-nand
> /system logging action set 3 bsd-syslog=no name=remote remote=44.24.244.8
> remote-port=514 src-address=0.0.0.0 syslog-facility=daemon
> syslog-severity=auto target=remote
> /system logging add action=remote disabled=no prefix="" topics=info
> /system logging add action=remote disabled=no prefix="" topics=warning
> /system logging add action=remote disabled=no prefix="" topics=error
> /snmp set enabled=yes contact="#HamWAN on irc.freenode.org"
> /snmp community set name=hamwan addresses=44.24.240.0/20 read-access=yes
> write-access=no numbers=0
> /system ntp client set enabled=yes primary-ntp=44.24.244.4
> secondary-ntp=44.24.245.4
> /ip firewall filter remove [find dynamic=no]
> /ip firewall mangle
> add action=change-mss chain=output new-mss=1378 protocol=tcp tcp-flags=syn
> tcp-mss=!0-1378
> add action=change-mss chain=forward new-mss=1378 protocol=tcp tcp-flags=syn
> tcp-mss=!0-1378
> /ip dhcp-server
> remove [find]
> /ip dhcp-server network
> remove [find]
> /ip dns
> set allow-remote-requests=no
> /interface wireless channels
> add band=5ghz-onlyn comment="Cell sites radiate this at 0 degrees (north)"
> frequency=5920 list=HamWAN name=Sector1-5 width=5
> add band=5ghz-onlyn comment="Cell sites radiate this at 120 degrees
> (south-east)" frequency=5900 list=HamWAN name=Sector2-5 width=5
> add band=5ghz-onlyn comment="Cell sites radiate this at 240 degrees
> (south-west)" frequency=5880 list=HamWAN name=Sector3-5 width=5
> frequency=5920 list=HamWAN name=Sector1-10 width=10
> (south-east)" frequency=5900 list=HamWAN name=Sector2-10 width=10
> (south-west)" frequency=5880 list=HamWAN name=Sector3-10 width=10
> /interface wireless set 0 radio-name="K7XST/Ballard-Gold"
> /snmp set location=47.677622,-122.404322
> /interface wireless
> set 0 disabled=no frequency-mode=superchannel band=5ghz-onlyn mode=station
> scan-list=HamWAN ssid=HamWAN wireless-protocol=nv2
> /ip dhcp-client
> add add-default-route=yes dhcp-options=hostname,clientid disabled=no
> interface=wlan1
> /ip dhcp-client
> add add-default-route=no use-peer-dns=no dhcp-options=hostname,clientid
> disabled=no interface=ether1
> On Sat, Jun 3, 2017 at 9:04 AM, Tom Hayward <tom@tomh.us> wrote:
>> On Fri, Jun 2, 2017 at 10:58 PM, Dave Stewart <dstewartgo@gmail.com>
>> wrote:
>> > Nope -- although I have an IP coming from Gold Mountain (apparently), my
>> > internet was coming from my local connection.  If I plug straight into
>> > the
>> > model over ethernet from my computer (instead of having the ethernet
>> > connected to my home internet router), I'm still not able to hit the
>> > net.
>> The basic instructions don't cover redistribution to your LAN. If you
>> just want to plug in directly, you can do this:
>> https://hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configuration.html#integrating-hamwan-into-your-lan
>> And there's a link there to a page with some more complex schemes.
>> But back up a minute, there's something really odd with your
>> connection. You have a decent signal into Gold-S2, have a DHCP address
>> assigned, but can't be pinged. Did you set up some funky firewall
>> rules? Any deviation from the instructions?
>> Tom
>> PSDR mailing list
>> PSDR@hamwan.org
