Thanks for the reply. Currently I have a /29 AMPR subnet that was used on packet and plan to setup to the WAN side on my Air Router.
https://portal.ampr.org/networks.php?a=region&id=195
The mesh network we are using is limited due to the adhoc nature (aredn.org) and bandwidth. Average through put in .5 - 1.5 Mbit depending. We would like to do a point to multipoint in addition to the mesh configuration.
Chad
KA7HAK
On Thu, Apr 6, 2017 at 1:42 PM, Tom Hayward <tom@tomh.us> wrote:
Hi Chad,
There are HamWAN users in Spokane and on the west side. We are very
eager to bridge that gap.
Jim K7LL is in Pullman and looking to link toward Spokane and Walla Walla.
To directly connect your network with HamWAN, you will need to use
public address space. You can get these addresses from AMPR if you
need (http://www.ampr.org/). What address space are you using
currently? HamWAN filters private address space from its routing
table, because it's assumed to be an accidental leak from someone's
home LAN. However, you could NAT or tunnel if you had to pass traffic
from a private network over HamWAN.
On Thu, Apr 6, 2017 at 12:49 PM, Chad Smith <chad@verishare.net> wrote:
> Greetings. Here in Yakima we use the AREDN.ORG firmware with Ubiquiti radios
> on 2397Mhz. I realize the HamWan is a different beast, however we are
> looking at expanding our network. Currently we are just in Yakima, Selah and
> getting into the lower valley toward tri-cities. There is also a tunnel to
> the Walla Walla mesh network. I would like to open a dialog with you folks
> about possible future expansion state wide as well and advise on updating
> out network.
> Regards,
> Chad Smith
> KA7HAK
> Node Map
> https://tinyurl.com/mtrmolu
> Facebook Group
> https://www.facebook.com/groups/696152693769185/
