Scott, thanks, I find that info helpful to better understanding the Winlink stance.  Hmmm…too bad that Winlink.org is pushing SSL and phasing out “true” telnet at some point.  Makes me wonder if there are aware of the growing use of HamWAN for Winlink client connections, and if so they are purposely discounting/ignoring it.  We need an allowed/supported solution for that to keep our self-policing ham operations low risk of FCC crack-downs or harassment from the replacement OOs (forget what they are now called).
I’m optimistic there’s a doable inexpensive solution, however temporary or long term, and I’m impressed with the postings I’m seeing on this here on this forum.  We’ve got the hams with needed skills & knowledge to come up with that.
From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Scott Currie
Sent: Tuesday, March 16, 2021 7:58 AM
Here is my, probably incomplete, understanding of things. Originally, connections to the CMS from either clients (Winlink Express) or gateways (RMS Packet, RMS Trimode) were on port 8772 using telnet. About a year ago they introduced port 8773 which uses SSL. For the WDT products, this is now the preferred port and is tried first. If the connection fails, they will try port 8772, and today this will still work. At some point port 8772 will be turned off. Non-WDT clients and servers (BPQ, Pat, Outpost) can still use port 8772 today, but will need to switch to port 8773 eventually. I do not know what the traffic looks like on port 8773. They say it is still telnet, so I don't know if they are using SSL for authentication, and then switching to plain text, or if they are establishing an encrypted tunnel and then sending telnet through the tunnel. I'll have to trace it and see what is going on.
Client and gateway connections to RMS Relay go over port 8772 using telnet, and this will not change. P2P telnet connections will continue to be unencrypted (the port default is 8772 but can be changed). RMS Relay connections to the CMS will be over port 8773 SSL.
I'm not smart enough to interpret FCC rules to know if encrypted authentication is OK, as long as the actual traffic is plain text.
-Scott, NS7C
On Tue, Mar 16, 2021 at 6:32 AM Steve - WA7PTM <psdr-list@aberle.net> wrote:
telnet mode?
> -Scott
>> Scott, thanks for that update, interesting.  “Telnet” is a misnomer in
>> (whereas SSH is encrypted).   It looks like the email client is connecting
>> internet.
>> --Stephen W9SK
>> Winlink Express Link Test:
>>    Successfully connected to a CMS through port 8772 in 253 Milliseconds
>>    Successfully connected to a CMS through port 8773 in 311 Milliseconds
>>    Successfully performed API service to api.winlink.org through port 443
>> in 756 Milliseconds
>> autoupdate2.winlink.org...
>>    Successfully checked autoupdate server through port 443 in 439
>> Milliseconds
>>    Successfully connected to www.winlink.org through port 443 in 47
>> Milliseconds
>>    Successfully connected to ftp://ftp.swpc.noaa.gov/pub/latest/SGAS.txt
>> -Scott, NS7C
>> hoster & client.  Winlink does NOT use encryption, thus is legal, and is
>> the primary application for my ARES team using HamWAN.  As Kenny points
>> FWIW, Stephen W9SK
>> Good luck,
>> Kenny, KU7M
>> Hi Phil,
>> dish.  As to “just over them”, a microwave shot consists of the direct,
>> cigar shaped “balloon” around the pure line of sight.  Items in the Fresnel
>> regular internet and HamWAN for a Winlink node.  My suggestion would be to
>> other if the one goes down.  You can also acquire routers that include
>> failover capability to automatically make that switch.  You can go more
>> Carl, N7KUW
>> PSDR
>> *To:* psdr@hamwan.org
>> and reporting status.  I's not linking to anything since the antenna is
>> still on the ground.  How much configuration can I do before mounting it on
>> my roof.  The only question in my sight path may be some trees but I think
>> I can aim just over them and get a signal.  My friend Bruce/WA7BAM will be
>> helping with the antenna installation on Wed afternoon.  Making progress...
>> *Phil Cornell  *
>> *W7PLC *
>> *SHARES NCS590*
>> *Hybrid Gateway W7PLC*
>> *TCARES  VP*
>> PSDR mailing list
>> PSDR@hamwan.org
>> PSDR mailing list
>> PSDR@hamwan.org
>> *-Scott*
>> PSDR mailing list
>> PSDR@hamwan.org
-Scott
