I'm presuming that you are PINGing the gateway (10.0.0.1), which in normal circumstances will respond to PINGs, but I thought I'd ask ...
On 2014-05-26 09:01, Dean Gibson AE7Q wrote:
Ah, I'd like the IP address you are PINGing.  What do you type after the command "ping"?
On 2014-05-25 10:22, Bob wrote:
The router is setup as follows:
          IP: 10.136.19.168
          Sub Mask: 255.0.0.0
          Gateway: 10.0.0.1
          DNS: 10.0.0.2
          Alt: 10.0.0.1
Bob
Sent: Saturday, May 24, 2014 9:33 PM
Subject: Re: [HamWAN PSDR] 1.2GHz to Paine [was: 44.x.x.x HamWAN network at Paine]
When you attempt to ping using the K7LWH/DD module, what IP address do you specify?
On 2014-05-24 14:36, Bob wrote:
Here are some observations and conclusion that I have come up with in adding the ID-1 to the Kirkland Emergency Communications Team’s tool box.  I have done a number of tests of the ID-1 from various locations in Kirkland in both the Digital Data (DD) mode and the Digital Voice (DV) mode.  I tested simplex paths (ID-1 to ID-1) and paths to the Lake Washington Ham Club (LWHC) DSTAR DV repeater and DD gateway nodes in Bellevue.
1.      There are a few locations in Kirkland that have direct visual line of site to LWHC Gateway in Belleview.  From those locations, pings are consistently returned in 100 to 200ms with an occasional loss.
2.      We have two location (Stations 22 and 25) are not visual but according to Radio Mobile modeling skim the terrain.  At these sights no ping are returned.
3.      At my home QTH (Lat: 47.694 Lon: -122.2161) I do not have a visual of the LWHC Gateway, but I get occasional pings returned.
4.      John Hays loan me a 1.23 GHz directional antenna. With the directional antenna I detected two paths to the gateway.  One was off a condo about 180 degrees from the gateway about a mile away; the other was off the NOAA building four miles awat at Sand Point about 15 degrees clockwise from the gateway.  This indicates the presents of multi-paths that could be interfering with the data even with good signal strength.
5.      I will also confirm the DV mode is more robust than the DD mode, but it too is affect by multi-path.
Bob – KE7JL
