telnet mode?
> -Scott
>> Scott, thanks for that update, interesting. “Telnet” is a misnomer in
>> (whereas SSH is encrypted). It looks like the email client is connecting
>> internet.
>> --Stephen W9SK
>> Winlink Express Link Test:
>> Successfully connected to a CMS through port 8772 in 253 Milliseconds
>> Successfully connected to a CMS through port 8773 in 311 Milliseconds
>> Successfully performed API service to api.winlink.org through port 443
>> in 756 Milliseconds
>> autoupdate2.winlink.org...
>> Successfully checked autoupdate server through port 443 in 439
>> Milliseconds
>> Successfully connected to www.winlink.org through port 443 in 47
>> Milliseconds
>> Successfully connected to ftp://ftp.swpc.noaa.gov/pub/latest/SGAS.txt
>> -Scott, NS7C
>> hoster & client. Winlink does NOT use encryption, thus is legal, and is
>> the primary application for my ARES team using HamWAN. As Kenny points
>> FWIW, Stephen W9SK
>> Good luck,
>> Kenny, KU7M
>> Hi Phil,
>> dish. As to “just over them”, a microwave shot consists of the direct,
>> cigar shaped “balloon” around the pure line of sight. Items in the Fresnel
>> regular internet and HamWAN for a Winlink node. My suggestion would be to
>> other if the one goes down. You can also acquire routers that include
>> failover capability to automatically make that switch. You can go more
>> Carl, N7KUW
>> PSDR
>> *To:* psdr@hamwan.org
>> and reporting status. I's not linking to anything since the antenna is
>> still on the ground. How much configuration can I do before mounting it on
>> my roof. The only question in my sight path may be some trees but I think
>> I can aim just over them and get a signal. My friend Bruce/WA7BAM will be
>> helping with the antenna installation on Wed afternoon. Making progress...
>> *Phil Cornell *
>> *W7PLC *
>> *SHARES NCS590*
>> *Hybrid Gateway W7PLC*
>> *TCARES VP*
>> PSDR mailing list
>> PSDR@hamwan.org
>> PSDR mailing list
>> PSDR@hamwan.org
>> *-Scott*
>> PSDR mailing list
>> PSDR@hamwan.org
