... my wording sounded weird re-reading that... I didn't mean that as a "flex"... lemme try again:   "I'm not familiar with these specific devices, but here's some things I've learned over the years"  ;-P
On Wed, Oct 30, 2019 at 12:42 PM Andrew Dickinson <andrew.b.dickinson@gmail.com> wrote:
I don't have one of these devices, so I'm relying on my decade-and-a-half of work experience operating networks in place of actual experience with the device
Do you have an IP address?
Can you ping the gateway IP?
Do you have a default route installed?
If these answers to all of those are "yes", then I've got a bunch of other questions about firewalls/acls and/or troubleshooting on the other end... but I'm guessing at least one of those is a "no".
-A
On Wed, Oct 30, 2019 at 12:18 PM Ric Merry <ricmerry@gmail.com> wrote:
For the most part things seem to be going good. I got 4 LEDs lit up before I proceeded with Client Set up.
I skipped the optional steps 16-17
All else seemed good until I cam to trace route and google ping.
Here is where I'm at. Hope I copied enough to get some answers but not too much.
Thanks!
[admin@K7ITE-Lookout] /interface wireless> /interface wireless
[admin@K7ITE-Lookout] /interface wireless> set 0 disabled=no frequency-mode=superc
hannel band=5ghz-onlyn mode=station scan-list="HamWAN" ssid=HamWAN wireless-protoc
ol=nv2
[admin@K7ITE-Lookout] /interface wireless> /ip dhcp-client
[admin@K7ITE-Lookout] /ip dhcp-client> add add-default-route=yes dhcp-options=host
name,clientid disabled=no interface=wlan1
[admin@K7ITE-Lookout] /ip dhcp-client> /interface wireless scan 0
Flags: A - active, P - privacy, R - routeros-network, N - nstreme, T - tdma,
W - wds, B - bridge
       ADDRESS           SSID       CHANNEL    SIG   NF SNR RADIO-NAME ROUTERO...
A RT B 74:4D:28:57:F6:BA HamWAN     5900/5/an  -64 -123  59 Lookout...
A RT B 74:4D:28:87:1E:AA HamWAN     5880/5/an  -79 -123  44 Lookout...
[admin@K7ITE-Lookout] /ip dhcp-client> /interface wireless monitor 0
                  status: connected-to-ess
                 channel: 5900/5/an
       wireless-protocol: nv2
                 tx-rate: 1.6Mbps-5MHz/1S
                 rx-rate: 1.6Mbps-5MHz/1S
                   bssid: 74:4D:28:57:F6:BA
              radio-name: Lookout-S2/WA7DEM
         signal-strength: -65dBm
     signal-strength-ch0: -65dBm
      tx-signal-strength: -67dBm
  tx-signal-strength-ch1: -92dBm
             noise-floor: -123dBm
         signal-to-noise: 58dB
                  tx-ccq: 14%
                  rx-ccq: 10%
   authenticated-clients: 1
        current-distance: 32
                wds-link: no
                  bridge: no
        routeros-version: 6.45.2
                 last-ip: 184.154.74.68
       current-tx-powers: 6Mbps:27(27/27),9Mbps:27(27/27),12Mbps:27(27/27),18Mbps:27(27/27),24Mbps:27(27/27),36Mbps:27(27/27),48Mbps:25(25/25),
                          54Mbps:24(24/24),HT20-0:27(27/27),HT20-1:27(27/27),HT20-2:27(27/27),HT20-3:27(27/27),HT20-4:27(27/27),HT20-5:26(26/26),
                          HT20-6:25(25/25),HT20-7:23(23/23)
     notify-external-fdb: no
[admin@K7ITE-Lookout] /ip dhcp-client> /tool traceroute 8.8.8.8
 # ADDRESS                          LOSS SENT    LAST     AVG    BEST   WORST STD-DEV STATUS
 1                                  100%    4 timeout
 2                                  100%    4 timeout
 3                                  100%    4 timeout
 4                                  100%    4 timeout
 5                                  100%    3 timeout
[admin@K7ITE-Lookout] /ip dhcp-client> /ping google.com
invalid value for argument address:
    invalid value of mac-address, mac address required
    invalid value for argument ipv6-address
    while resolving ip-address: could not get answer from dns server
[admin@K7ITE-Lookout] /ip dhcp-client> /system ntp client print
           enabled: yes
       primary-ntp: 44.24.244.4
     secondary-ntp: 44.24.245.4
  server-dns-names:
              mode: unicast
   dynamic-servers: 44.24.244.4,44.24.245.4
     poll-interval: 16s
