Hi Bart,
My view toward Gold Mtn is blocked, but my clear view is more toward
Bainbridge Island, the Bangor Base, Green Mtn etc.
Do You think there is a chance that I will be able to make this work? I
don't mind taking a chance and trying it if there is any hope of it working.
Thank You Bart.
73
-Grace
KC0BTM
NNNN
z
On 4/23/2017 2:22 PM, Bart Kus wrote:
> More important than the gear will be your signal path. Checking your
> callsign, I don't see where that building has clear view of the
> sound. I see it's buried among giants. Do you have any zoomy photos
> showing Gold Mtn?
> If you do indeed have a path, then any client should do. Have you
> read
> http://hamwan.org/Standards/Component%20Engineering/ Client%20Hardware.html
> ? We use a QRT-5 @ The Westing Building (2 blocks from you) to link
> to Gold Mtn. You can use something higher gain if you have the room.
> We needed something that could press up against the glass at a high
> angle due to the orientation of the Westin.
> --Bart
> On 4/23/2017 1:24 PM, Grace B Thomson wrote:
>> Hello,
>> I live on the 5th floor of an apartment building in Belltown (98121)
>> with windows facing Southwest. I am on 3rd Avenue, so there are
>> buildings facing me, but I have a clear shot across the Sound to the
>> WNW.
>> I wonder if anyone can advise me regarding an antenna that might work
>> mounted indoors (near the window) that has a good chance of working
>> well. Unfortunately, the building does not allow anything to be mounted
>> outside, so I am limited in this regard.
>> Would it be better to have a device separate from the antenna (Metal
>> 5SHPn for example), or a unit with an antenna built in?
>> If You think an indoor solution is possible, Can You suggest some of the
>> best hardware configuration alternatives. I am on a fixed income, so I
>> am looking for an economic solution to start out with. If it looks like
>> it is possible, I would like to purchase equipment and get this working
>> within the next month or so.
>> Thank You in advance for any thought or advice that You may have.
>> Regards.
>> 73
>> -Grace
>> KC0BTM
>> NNNN
>> z
>> PSDR mailing list
>> PSDR@hamwan.org
