And Rob in before, I chose the wrong sector to start with... ;-)I was also able to get in fine and it looks like all the admin accounts are there.Kenny_______________________________________________On Wed, Aug 19, 2020 at 4:00 PM Rob Salsgiver <rob@nr3o.com> wrote:_______________________________________________I was able to login just fine right now. Looks like you’re back up and going on Baldi S3.
From: PSDR [mailto:psdr-bounces@hamwan.org] On Behalf Of Scott Currie
Sent: Wednesday, August 19, 2020 3:40 PM
Subject: Re: [HamWAN PSDR] Help with userid
Baldi
NS7C-Auburn
On Wed, Aug 19, 2020 at 3:37 PM Kenny Richards <richark@gmail.com> wrote:
which node are you connected to?
On Wed, Aug 19, 2020 at 3:31 PM Scott Currie <scott.d.currie@gmail.com> wrote:
OK, after some pain, I think I have everything back to normal, latest firmware, passwords documented, and admin keys loaded. If an admin can try logging in and let me know, that would be great. I'll have the router up for any 30 minutes or so.
-Scott
On Wed, Aug 19, 2020 at 10:47 AM Scott Currie <scott.d.currie@gmail.com> wrote:
OK, thanks for trying. I thought I had all the keys saved per the original setup instructions.
I'll reset the router and start over, and then save my password securely!!!
-Scott
On Wed, Aug 19, 2020 at 10:27 AM Nigel Vander Houwen <nigel@nigelvh.com> wrote:
My key doesn’t work either, so I’m not sure the admin keys are on there. I think you’re likely in for a reset.
On Aug 19, 2020, at 10:22 AM, Doug Kingston <dpk@randomnotes.org> wrote:
Tried to log in, but your node does not have my public key.
It will need one of the older netops to help you.
-Doug-
On Wed, Aug 19, 2020 at 10:11 AM Scott Currie <scott.d.currie@gmail.com> wrote:
I'm embarrassed, but I forgot my password on my personal node (I haven't turned it on in a while). Before I do a complete reset and start over, any chance one of the admins can connect and reset my password? It is on Baldi right now, NS7C@Baldi
-Scott
-Scott
-Scott
-Scott
