Bart’s suggestion is a better way as it is much more secure.  Allowing FTP to be run at any time in RouterOS is asking for trouble, as it can be potentially be used for a bad actor to infect your device.  SCP (Secure Copy Protocol) is not only encrypted  but using Secure Shell (SSH) to access it helps prevent problems.
From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Bart Kus
Sent: Wednesday, November 23, 2022 10:53 AM
To: Puget Sound Data Ring <psdr@hamwan.org>; Jamie Owens <jlowens76@gmail.com>
Cc: Rob Martin <rgmrob@yahoo.com>
Subject: Re: [HamWAN PSDR] RouterOS question
Alternatively, you can push from Windows, by having an SSH key installed and using SCP:
https://stackoverflow.com/questions/35292681/pscp-file-from-windows-to-linux-using-private-public-keys
On 11/23/2022 12:59 AM, Jamie Owens wrote:
Yep just use fetch with mpde=ftp and setup ftp server on windows box, problem solved
On Wed, Nov 23, 2022 at 12:57 AM Tom Hayward <tom@tomh.us> wrote:
Sounds like you just need /tool fetch.
On Tue, Nov 22, 2022, 19:00 Rob Martin via PSDR <psdr@hamwan.org> wrote:
I am trying to achieve something using RouterOS scripting, and I'm hoping that here I might find the appropriate expertise.
From a script running in a Mikrotik router I wish to pull in a copy of a file from an attached Windows computer. The computer is on the same subnet as the router.
By way of illustration:
     A file called test.xxx exists on a Windows computer in the folder c:\aaa\
     I want a copy of this file to appear in the attached router /file list. This copy "event" could be either a push from the computer, or a pull from the router.
When using Winbox, this function is achieved easily using "drag and drop", but I need to automate the function.
Thanks.
K7QJ
Jamie Owens
