Clear line of sight. Please validate with the tower
picture attached.
Installed the following:
MikroTik mANT30 PA parabolic dish antenna 5GHz
30dBi MTAD-5G-30D3-PA
Mikrotik BaseBox 5 RB912UAG-5HPnD-OUT 5GHz Outdoor
Wireless AP Gigabit USB OSL4
Questions:
Q1) Is the antenna tower on the right in the
picture the right site?
Q3) I was watching the signal strength on the
routerboard while running "/interface wireless scan 0”.
Nothing showed up on the terminal session and no signal
strength LED’s lit up. I moved it left to right and adjusted
azimuth each time I stopped.
Q4) How long should you wait to acquire the signal
between each time you move it?
Q5) Is there anything like the signal strength
tones aiming a DirecTV dish?
Thanks for your help!
-Paul KK7AMW
[admin@KK7AMW-Issaquah]
> export
# sep/08/2021
16:57:46 by RouterOS 6.48.4
# software id =
H1Z0-P9F3
# model =
912UAG-5HPnD
/interface wireless
set [ find
default-name=wlan1 ] band=5ghz-onlyn country=no_country_set
disabled=no
frequency-mode=superchannel radio-name=KK7AMW/Issaquah-Tiger
scan-list=HamWAN
ssid=HamWAN \
wireless-protocol=nv2
/interface list
add name=WAN
add name=LAN
/interface wireless
channels
add band=5ghz-onlyn
comment="Cell sites radiate this at 0 degrees (north)"
frequency=5920
list=HamWAN name=Sector1-5 width=5
add band=5ghz-onlyn
comment="Cell sites radiate this at 120 degrees (south-east)"
frequency=5900 list=HamWAN name=Sector2-5 width=5
add band=5ghz-onlyn
comment="Cell sites radiate this at 240 degrees (south-west)"
frequency=5880 list=HamWAN name=Sector3-5 width=5
add band=5ghz-onlyn
frequency=5920
list=HamWAN name=Sector1-10 width=10
add band=5ghz-onlyn
frequency=5900 list=HamWAN name=Sector2-10 width=10
add band=5ghz-onlyn
frequency=5880 list=HamWAN name=Sector3-10 width=10
/interface wireless
security-profiles
set [ find
default=yes ] supplicant-identity=MikroTik
/snmp community
/system logging
action
set 3
remote=44.24.244.8
/interface list
member
add interface=wlan1
list=WAN
add list=LAN
/ip address
/ip dhcp-client
add disabled=no
interface=wlan1
/ip dns
set
servers=192.168.86.9
/ip firewall mangle
add
action=change-mss chain=output new-mss=1378 protocol=tcp
tcp-flags=syn
tcp-mss=!0-1378
add
action=change-mss chain=forward new-mss=1378 protocol=tcp
tcp-flags=syn
tcp-mss=!0-1378
/ip route
add distance=1
gateway=192.168.86.1
/ip service
set telnet
disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=222
set api disabled=yes
set api-ssl
disabled=yes
/snmp
set
contact="#HamWAN-Support on
irc.freenode.org"
enabled=yes
location=47.516944,-122.0452
/system clock
set
time-zone-name=America/Los_Angeles
/system identity
set
name=KK7AMW-Issaquah
/system logging
add action=remote
topics=info
add action=remote
topics=warning
add action=remote
topics=error
/system ntp client
set enabled=yes
primary-ntp=44.24.244.4 secondary-ntp=44.24.245.4
/system routerboard
settings
set
boot-device=try-ethernet-once-then-nand
