John, Yes, in this case HamWAN is being used as the connection between Winlink email client (and its associated local RMS Relay) and the CMS on the internet, so it’s going out OTA on the 5GHz ham band..  It could be that a solution is to direct the traffic via HamWAN to an internet-based RMS (or CMS) that does not use SSL which would then upstream to the mother ship CMS using SSL?  If so, perhaps we can get one setup on Azure/AWS/GoogleCloud for that purpose.
From: PSDR <psdr-bounces@hamwan.org> On Behalf Of John D. Hays
Sent: Monday, March 15, 2021 9:16 PM
Are those over the airwaves?
On Mon, Mar 15, 2021, 17:56 Scott Currie <scott.d.currie@gmail.com> wrote:
This is not entirely true. Winlink does use TLS/SSL connections for some things. The normal telnet connection is now SSL (will fallback to non-SSL if the connection fails). Also, RMS Gateway to the CMS is now SSL. Telnet P2P and telnet to RMS Relay is not SSL. I believe updates are also SSL now.
Winlink Express Link Test:
Test started 2021/03/16 00:52 UTC
Testing CMS telnet connection to cms.winlink.org through port 8772...
  Successfully connected to a CMS through port 8772 in 253 Milliseconds
Testing CMS SSL telnet connection to cms.winlink.org through port 8773...
  Successfully connected to a CMS through port 8773 in 311 Milliseconds
Testing API service access through port 443 to api.winlink.org...
  Successfully performed API service to api.winlink.org through port 443 in 756 Milliseconds
Testing Autoupdate server access through port 443 to autoupdate2.winlink.org...
  Successfully checked autoupdate server through port 443 in 439 Milliseconds
Testing connection to web site - www.winlink.org:443
  Successfully connected to www.winlink.org through port 443 in 47 Milliseconds
Testing FTP connection to SFI site - ftp://ftp.swpc.noaa.gov/pub/latest/SGAS.txt
  Successfully connected to ftp://ftp.swpc.noaa.gov/pub/latest/SGAS.txt through port 20/21 in 1522 Milliseconds
Test completed successfully.
-Scott, NS7C
On Mon, Mar 15, 2021 at 5:45 PM Stephen Kangas <stephen@kangas.com> wrote:
Phil, an example of the ham band traffic that Kenny mentioned is not permitted by the FCC is encrypted communications traffic…this means the majority of websites your visit today and many email hosters, since websites commonly use TLS/SSL encryption (indicated by “https” in front of the URL in your browser address bar) or encrypted settings in your email hoster & client.  Winlink does NOT use encryption, thus is legal, and is the primary application for my ARES team using HamWAN.  As Kenny points out, certain routers (not inexpensive home models) can be used to split that traffic appropriately, but it is not an easy setup unless you have a background in data networks or cybersecurity…so it’s far easier to either use HamWAN just for your dedicated ARES laptop use or switch a cable back and forth using one pipe at a time.
FWIW, Stephen W9SK
Sent: Monday, March 15, 2021 12:49 PM
Good luck,
Kenny, KU7M
Hi Phil,
As to trees, they are an absolute show stopper. You must have clear, visual, line of sight to the HamWAN site you are shooting to. Hopefully you will have that, or can achieve that, from where you plan to mount the dish.  As to “just over them”, a microwave shot consists of the direct, pure line of sight, but also what is referred to as the Fresnel zone – a cigar shaped “balloon” around the pure line of sight.  Items in the Fresnel zone (including trees) can reduce the amount of signal you have, so you may not get optimum performance, but some.
In your initial post you commented about how to balance between your regular internet and HamWAN for a Winlink node.  My suggestion would be to just leave it on one (whichever one) as the norm, and only switch to the other if the one goes down.  You can also acquire routers that include failover capability to automatically make that switch.  You can go more advanced with load sharing and such between multiple connections, but that requires much better understanding of internet routing, and for a winlink node basic failover will serve your purpose.
Subject: [HamWAN PSDR] Newbie
OK, I figured out my problem and I now have Winbox talking to the radio and reporting status.  I's not linking to anything since the antenna is still on the ground.  How much configuration can I do before mounting it on my roof.  The only question in my sight path may be some trees but I think I can aim just over them and get a signal.  My friend Bruce/WA7BAM will be helping with the antenna installation on Wed afternoon.  Making progress...
Phil Cornell
W7PLC
SHARES NCS590
Hybrid Gateway W7PLC
TCARES  VP
-Scott
