Bart / all, I had talked a while ago to Bart and some of the others about upgrading the SnoDEM sectors to MIMO. I procrastinated due to working on repeater problems and other items and didn't get them ordered until today, but they are ordered. 1) (3) complete sectors with shields, stationbox, and modems 2) (3) additional shields to go with the existing sectors and modems I already have here at the house. (1) of those sectors is already allocated to the Haystack repair mission. This will leave (2) complete sectors in my "stock" here at the house. If not used for other projects, may get allocated to a hospital or other site shortly. I'm hopeful it will all arrive with enough time that I can do programming / configs ahead of time. Rob -----Original Message----- From: PSDR [mailto:psdr-bounces@hamwan.org] On Behalf Of Bart Kus Sent: Thursday, April 26, 2018 12:58 AM To: HamWAN Deploy; Puget Sound Data Ring Subject: [HamWAN PSDR] SnoDEM repair mission Hello, SnoDEM is in need of some repairs: 1) Gold.SnoDEM modem is dead, needs to be replaced. 2) All the wiring is flailing in the wind since the zip ties broke (https://imgur.com/a/wkghAp0). Cables need to be properly supported, with cable ladder clamping hardware. However, this was our second site, and we used cable that was too thick to be compatible with tower cable cushions, so....all the cabling has to be replaced with proper diameter cable. 3) The dishes are not shielded, so they pick up way too many local signals, and each other. Every dish has to be lowered to the ground, radome removed, and shield kit bolted on, then raised up again, re-attached, and re-aimed. 4) Optionally, the sectors may be upgraded to MIMO. This is still TBD. 5) Optionally, the last dish may be installed, bearing north for Lookout. This will require at least 2 climbers on the tower, and a bunch of ground crew to help with cable hoisting and dish shield replacement. Each shield will probably take 1 hour to replace, since they have so many bolts. I'm wondering who would be available and willing to help on the 12th and 13th of May. You don't have to do both days, so let me know your day-by-day availability if you can help. Please hit Reply and not Reply All, to minimize list spam. Thanks, --Bart _______________________________________________ PSDR mailing list PSDR@hamwan.org http://mail.hamwan.net/mailman/listinfo/psdr
Can you get me details on what you ordered for our site? I'd like to see if I can fund this hardware. Perhaps just some of it. That would free up your hardware for another site. Scott N7SS On Thu, Apr 26, 2018, 4:19 PM Rob Salsgiver <rob@nr3o.com> wrote:
Bart / all,
Will send copies of invoices later today
Scott N7SS
Bart / all,
participants (3)
rob -
Rob Salsgiver -
Scott Honaker
