Baldi deployment report
Hello, We deployed stuff @ Baldi today. First, the good news: 1) We installed the cable between the buildings, and got all of them on the gigabit LAN. 2) The 24-port switch for the middle building didn't arrive on time, so we're using the full switch that was there already. 3) We aligned the Beacon.Baldi dish and managed to get another 10dB of signal out of it now that it's focused solely on Beacon. 4) We got access points deployed into all the buildings. 5) We got the link to CampMurray working at last. The 3ft dish was discovered to be damaged and had to be replaced with a 2ft from my personal inventory. This will need an RF Armor shield, and an additional expense report for the Baldi deploy budget to cover the cost of the dish itself. Now for not great news: 1) The Ethernet link between the northernmost building and the new Rattlesnake.Baldi dish seems to be faulty. It was raining hard when we were installing this, so maybe there's water in the connector. It's also deployed pretty close to lots of VHF/UHF antennas, so maybe the RFI is killing the Ethernet. We need to go back on a dry day, hopefully with a cable analyzer, and examine the situation. If it's VHF/UHF RFI, then we'll need to run fiber to the modem. I have disabled the power to the dish for now, on the theory that water is causing PoE arcing at the modem contacts and we don't want that electrolysis process to continue. Power draw to the modem is not unusual, about 3.2W, although it has been observed to be quite variable at times, from 3W to 4W. 2) The AP in the northernmost building appears to have really bad performance. I had a hard time pinging it over WiFi from within the shack. Had to resort to using wired Ethernet to get any packets moving and work done. I've no idea the cause of this. Perhaps a spectrum scan is required. 3) The VHF DMR up there appears to have been static-IP configured and didn't migrate properly. We'll need some follow-up remote work to re-program the repeater for DHCP. I think that's everything noteworthy. --Bart
Thanks for the update and all the hard work. Despite your no-so-good news, there was lots of good progress as well. -Doug- On Sat, Jun 6, 2020 at 11:59 PM Bart Kus <me@bartk.us> wrote:
Sounds like a long day Bart. The local LAN has been a dream up there for years. You put the DMR router on the routing protocol now too, great. And the old SXT5 link to Baldi sector is gone: wlan1.baldi.af7pr-baldi.hamwan.net (44.24.240.219) ether1.baldi.af7pr-baldi.hamwan.net (44.25.137.34) Mike, Rob, Rod, the local DHCP server for 44.25.137.33/28 was on the link radio. Additionally, the switch ports are now bridged to the local LAN. Devices should be up, but will have new ip addresses on the Baldi LAN, instead of in 44.25.137.22/38 Bart says the VHF repeater didnt pull a DHCP address from Baldi LAN, it was being used as a master for a while, so it's config required a static ip address. I put theVHR repeaters switch port8 into the bridge for .33/28, now called Building2. And vhf.af7pr-baldi.hamwan.net is now back online. There is very little necessity in maintaining 44.25.137.33/28 address space anymore, there is plenty of space on baldi LAN. Perhaps there are some reasons I'm not anticipating? We can still use that block, moving the old devices back to how they were numbered. Otherwise, we can find the new addresses and update DNS. --- Dylan Ambauen 360-850-1200 On Sat, Jun 6, 2020 at 11:59 PM Bart Kus <me@bartk.us> wrote:
Dylan, Were you able to access the Pi for programming the radios? Thanks Kenny On Sun, Jun 7, 2020 at 10:04 AM Dylan Ambauen <dylan@ambauen.com> wrote:
Kenny, I have not yet determined the Pi's new address. I assume r1.baldi is the dhcp server for the new LAN, but I don't seem to have access to r1.baldi. No problem. Instead, moved the Pi's switch port to bridge=Building2, and configured a DHCP server for the segment, waiting for the Pi to pull a new ip address. Also realizing that Bart named the DMR router's new loopback as r2.baldi, very clean, thank you Bart. --- Dylan Ambauen 360-850-1200 On Sun, Jun 7, 2020 at 11:40 AM Kenny Richards <richark@gmail.com> wrote:
Dylan,
Thanks Kenny
participants (4)
Bart Kus -
Doug Kingston -
Dylan Ambauen -
Kenny Richards
