Internet Maintenance Notification
FYI: I will be moving HamWAN off of the Cisco 7206 and over to the Cisco ASR 9k routers today so it's possible you may see a blip in the internet access if any at all. Tim Osburn www.osburn.com 206.812.6214 W7RSZ
This is completed Tim Osburn www.osburn.com 206.812.6214 W7RSZ On Mon, 16 Jun 2014, Tim Osburn wrote:
Date: Mon, 16 Jun 2014 08:15:54 -0700 (PDT) From: Tim Osburn <tim@osburn.com> To: Puget Sound Data Ring <psdr@hamwan.org> Subject: Internet Maintenance Notification
Where's the http://www.osburn.com/140409-hamwan-outage-notification.pdf ??? On Mon, Jun 16, 2014 at 10:41 AM, Tim Osburn <tim@osburn.com> wrote:
This is completed
-- Ryan Turner
Ryna, There was no outage due to there being two redundant BGP peers to us from HamWAN. Tim Osburn www.osburn.com 206.812.6214 W7RSZ On Mon, 16 Jun 2014, Ryan Elliott Turner wrote:
Date: Mon, 16 Jun 2014 11:38:31 -0500 From: Ryan Elliott Turner <ryan.e.t@gmail.com> Reply-To: Puget Sound Data Ring <psdr@hamwan.org> To: Puget Sound Data Ring <psdr@hamwan.org> Subject: Re: [HamWAN PSDR] Internet Maintenance Notification
This is completed
Ryan Turner
Speaking of outages, there has been no fix (I'm not saying that anyone in HamWAN is at fault) for the loss of connectivity to 44.x.x.x nodes in (for example) Germany, for almost a week. This isn't urgent, but where's the best place to escalate that to, 44net??? -- Dean On 2014-06-16 17:50, Tim Osburn wrote:
This is completed
Ryan Turner
Dean, I'm not sure how closely you follow the 44net mailing list, but we're sort of at an impasse with our AMPR gateway. Here's an explanation of the issue with a lot of background. IPv4 addresses are scarce, and the organization that has offered HamWAN free IPv4 address space for use on the Internet is AMPR. These happen to be addresses from the 44.0.0.0/8 network, and we use various subnets within this block. 44.24.240.0/20 is our primary network and is accessible from the internet. Most AMPR networks are not fortunate enough to have upstream providers that let them announce their own address space on the Internet, so they use gateways to tunnel 44.x.x.x packets between AMPR subnets. A list of AMPR subnets and their gateways is published, and gateway operators must keep their gateways in sync with this list. Even though we are accessible from the internet without tunnels, we have to host a tunnel gateway so that these networks can talk to us using 44.x.x.x source addresses. We use another AMPR address, 44.24.221.1, as our AMPR gateway. We announce this, too, so that anyone with Internet service can access this gateway. Our gateway's subnet, 44.24.221.1/24, is not listed as an AMPR route, so routing to 44.24.221.1 should fall onto their default route from their ISP. Unfortunately, there are some popular AMPR configuration scripts that use a shortcut to make their routing simpler: they hard code a route 44.0.0.0/8 via UCSD. This hard-coded route gets priority over the default route, so packets to our 44.24.221.1 gateway get forwarded to UCSD, instead of through the default internet path. This is wrong. You might ask, why can't UCSD just send the packet our way? It turns out UCSD also has some routers with hard-coded 44.0.0.0/8 routes pointing away from the Internet. The solution is two-fold: 1. Avoid relying in UCSD whenever possible. The current AMPR design does this by creating tunnels directly between every AMPR gateway. 2. Don't hard code routes. Get all routes from automatic routing protocols or, when necessary, the route file distributed by AMPR. In the case of your loss of connectivity to German sites, we see the packets leave our network and never come back. This looks to me that they have a routing issue on the return path, very likely the problem I describe above. All six of the "broken" examples you gave use 141.75.245.225 as a gateway, so I'd start there. Tom KD7LXL
Some contacts in the CC ------------------------------ John D. Hays K7VE PO Box 1223, Edmonds, WA 98020-1223 <http://k7ve.org/blog> <http://twitter.com/#!/john_hays> <http://www.facebook.com/john.d.hays> On Mon, Jun 16, 2014 at 7:25 PM, Tom Hayward <esarfl@gmail.com> wrote:
participants (5)
Dean Gibson AE7Q -
John D. Hays -
Ryan Elliott Turner -
Tim Osburn -
Tom Hayward
