Latest recommendation for Cat 5e/6 outdoor rated cable
I thought this information was at https://hamwan.org <https://hamwan.org/> somewhere but I can’t locate it. What make and model of Cat 5E/6 cable do you recommend for outdoor (exposed to sunlight) use? We’re looking at an outdoor run of no more than 200 feet to get to our dish/router. I’d appreciate recommendations for shielded RJ45 connectors, too. Thanks and 73, Steve Magnuson AG7GN
Historically we have used trueCABLE CAT5e Outdoor... On Thu, Feb 8, 2024 at 12:49 PM Steve Magnuson <steve.magnuson@gmail.com> wrote:
Thanks and 73,
_______________________________________________ PSDR mailing list PSDR@hamwan.org https://mail01.fmt.hamwan.net/mailman/listinfo/psdr
Steve, There are all sorts of outdoor rated cable options that will work perfectly fine. We end up mostly using Ubiquiti TC-PRO (https://www.amazon.com/Ubiquiti-Networks-TOUGHCable-Shielded-Ethernet/dp/B00...) because it meets our outdoor & shielded requirements, and works well with our tower hardware. No reason you have to make the same choice though. Nigel
Thanks and 73,
I’ve used Cables4Sure 04100-BL Cat5e Outdoor Black Above Ground Bulk Cable sitting on my asphalt shingle roof for 2.5 years without a problem. However I learned that a mouse can easily eat through the wiring - I use the same wiring for outdoor POE cameras. The chewed cable was on the ground in my forested backyard.
On Feb 8, 2024, at 12:48 PM, Steve Magnuson <steve.magnuson@gmail.com> wrote:
Thanks and 73,
Bart has recently recommended https://www.perfect-vision.com/Shop/Product/PVCAT5GFDT-BLK-RIB On Thu, Feb 8, 2024 at 1:00 PM Paul Sundquist <psundquist@foxhill.org> wrote:
I thought this information was at https://hamwan.org < https://hamwan.org/> somewhere but I can’t locate it. What make and model of Cat 5E/6 cable do you recommend for outdoor (exposed to sunlight) use? We’re looking at an outdoor run of no more than 200 feet to get to our dish/router.
Thanks and 73,
participants (5)
Darcy Buskermolen -
Kenny Richards -
Nigel Vander Houwen -
Paul Sundquist -
Steve Magnuson
